Front Sway Bar End Link HELP!! 2018 TRD Premium
fsaral77
I ordered a set of Nolothane Sway Bar Front end links off Amazon and they said it fit my vehicle but the nut sizes are different. The OEM end links I have are 17mm and the Nolothane links are 19mm? I have a TRD premium 2018.
LINK
Everywhere I Look the end links are 19mm. Anyone have a good part number for me for the 17mm?
Not to be that guy.. but I am totally going to be that guy.
Reason for replacing the end links? After installing my Dobinson's lift I installed front end links from Overland Custom Design, really glad I made that choice. The Nolothane links just look fragile, and a break waiting to happen. The OCD links are heavy duty, adjustable, forged and sealed, and fit perfectly.
I'm not quite sure why you're replacing the links to begin with unless you damaged them?
Also the size of the nut shouldn't matter? As long as the threaded portion is still close to the factory size (M12x1.25 IIRC) and the correct length to go through the spindle hole and the sway bar are the same you should be able to use whatever nuts they supplied you? Or am I mis-reading what you're saying?
Ambrose67
