Front Weld on Recovery/Tow Point?
cbielat
Senior Member
Has anyone done or know the best point in which to weld on recovery tabs? I don't have a front bumper/winch yet and need a good front recovery point. I want to know the best location as to where to weld these on the front portion of the frame.
Thanks guys!
Moved to Offroading section.
Helps to know what year truck.
How good a welder are you?
It's got to be a damn strong weld.
What about bolt on?
What about bolt on?
2011
I'm not a welder but I know a very seasoned one
I'd rather have it welded on. Definitely don't trust the stock bolt on tie down hooks when recovery forces are factored in.
The strongest place for a recovery point is going to be in line with a frame rail. Putting it between the frame rails will require extra reinforcement.
So I shouldn't just weld it to the frame rails themselves.
If you really want a uber-strong recovery point and don't have a bumper, that's what I'd do, weld it directly on/under the frame rail. But I don't know what's in the way, or how much you'd have to cut off if/when you get around to putting on a steel bumper.
Why don't you think the factory recovery point is good enough?
I think the factory recovery points are made for a light recovery at best more so for strapping the vehicle down while on a flat bed or something along those lines. I wouldn't trust pulling on those little hooks for what we do! When i put my front bumper on i cut mine off and they were maybe a 1/4'' thick, I wouldn't trust that pulling him out of something or over something they would probably snap off or bend. I have a 4th gen though so i haven't seen the ones on the 5th but i would assume they are the same.
They're different. The 5th gen points are quite a bit more beefy.
BillM777
