FS: 17x8 Konig CounterSteer Type X - CORONA, CA
At this time we don't have any plans to do so, but if the demand is there it is definitely something that we can work on. We do offer a 17x8.5" FN Wheels Five Star, and we have a different 17x9" wheel in the works.
Are the 17" Five Stars so new they haven't been added online yet? Hoping to upgrade wheels and tires to 285's this summer and the Five Star has always been my favorite of your designs
Would there be anyway to get some more info on these (price, colors, availability), either here or by PM?
Thanks in advance!
- Jeff
Thanks in advance!
- Jeff
Hi Jeff!
I'm glad you like the Five Stars! The 17x8.5" Five Stars have been out for a little while now (a little less than a year), but we haven't added them to our website yet. Here are the specs:
FN Wheels Five Star
Diameter: 17"
Width: 8.5"
Offset: -6mm
Backspacing: 4.5"
Load rating: 955KG (2,100lbs+)
Weight: 22lbs (approximate)
Certification: JWL-T, VIA, SAE J-2530, DOT approved
Colors: Anthracite light gunmetal, matte black and matte bronze
Toyota specifics: 106mm hub centric for Toyota hubs, lug holes drilled for 12mm Toyota wheel studs for a snug fit, and center machined to accept flat snap-in OEM TRD center cap.
Price: $899 for a set of four including shipping anywhere within the contiguous 48 states (please contact us for a quote if you are outside the contiguous 48).
fnwheels-albums-fn+wheels+five+star+1785-picture33102-fn-wheels-five-star-matte-black-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33103-fn-wheels-five-star-matte-black-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33100-fn-wheels-five-star-anthracite-light-gunmetal-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33101-fn-wheels-five-star-anthracite-light-gunmetal-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33098-fn-wheels-five-star-matte-bronze-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33099-fn-wheels-five-star-matte-bronze-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fivestar1-Edit_zpsee5cb5fe.jpg~original
This is to help people choose, a photo of my matte bronze. Love these wheels. Also super easy to clean and so JDM!
You guys need to offer the 9" widths with a much more negative offsets. Once you lift these trucks, the stance shrinks an inch and these wheels suck into the wheel well. Several members run your wheels with spacers which in my opinion defeats the purpose of running custom wheels.
My 360 forged wheels are 9" width with negative 25 offset. With the truck lifted, this is near flush with the fender. I would consider buying a second set from you folks if you offered the same or more aggressive offset on both your countersteer Xs or your FN BFD's.
Finally got ours installed and very happy with the stance. The combination of these rims and 285s put us approx 1/2" past the fender wheel. Oem in comparison
Dustin was a great guy to work with. My new set of countersteers in the new gunmetal color are shipping out today. Will post pics as soon as I get them mounted on my new 4runner!
I like the bronze but the no matching center cap part kills it for me. Prob going to get some. CountersteerXs in black or gun metal soon.
Got my wheels wrapped and on the truck! Thanks to Dustin for all the help and awesome service! These are the new darker gunmetal color and the pics do them no justice.
603e445f-f315-41e4-b13e-14fe9c1bfdcd.jpg~original
you can see how different they look depending on the light
IMAG1854.jpg~original
IMAG1851.jpg~original
IMAG1848.jpg~original
Just picked up a set of Gunmetal Type X's at the shop in Orange and I have to repeat what everyone else has said, Dustin is top notch all the way.
I'll spare the details, but he went WAY above and beyond to get me into some wheels.
It's awesome to know that guys like him exist and cater to our crowd.
Give him your business and you will be a happy customer.
[MENTION=112299]Formidable[/MENTION] - Thanks for your feedback. We do offer two 17" models with negative offsets : 17x8" / -10mm offset Konig Countersteer Type X and the 17x8.5" / -6mm FN Wheels Five Star. These wheels push the wheels out approximately 1.25" and 1.3" (per corner) respectively when compared to an OEM 17x7.5" Trail / SR5 wheel.
We also offer a 17x8" / 0mm offset Konig Six Shooter wheel which pushes the wheels out approximately .84" more than the OEM wheels.
There are a number of posts showing the stance of our wheels on 4th and 5th Gen 4Runners as well, and the wheels are not sunken in (they sit flush our slightly outside the fender line). The 17x8" / 0mm offset wheels fit about flush on lifted 4Runners, and the 17x8" / 17x8.5" negative offset wheels put the wheel/tire approximately .5" - 1.0" outside the fender. I suspect your 17x9" / -25mm offset wheels put the tire about 2.0" +/- outside the fender, which is a little too aggressive for most of the 4Runner owners that I talk to.
To my knowledge most of our customers are not using wheel spacers with our wheels, as wheel spacers are not necessary for the majority of our customers. There are a few customers with more extreme setups that have added wheel spacers, but they are definitely in the minority. For the majority of 4th and 5th Gen 4Runner owners that I speak with lower offsets (into the -20mm or less range) and wider widths (9" +) would make their 4th and 5th Gen 4Runners undriveable.
With that said, we are always and have always been very receptive to offering new and unique fitments that our customers with specific needs request. We can definitely develop wider and even lower offset wheels if we have enough customer demand for them. If we have enough customer demand we can turn the wheels into a full production piece with a price point the same or similar to our new wheels.
Otherwise, you mentioned that you have custom forged wheels right now. We have the capability to make our some of our designs in custom, one-off forged versions with specific widths and offsets as well. The cost is considerably higher due to the nature of making wheels one set at a time vs. a full production run, but it is definitely something that we can do.
I don't want to take this thread too off topic, but please PM me, e-mail me: [email protected] or give me a call if you want to discuss any of these custom options in further detail. Thanks again for your feedback! Any and all feedback definitely helps us to continue to make the wheels that 4Runner owners want.
Can you please post some pictures of the center caps that are included with these? Wondering what they look like installed. Thanks!
Here's [MENTION=101457]KiruxaT4R[/MENTION] with matte bronze and matte bronze caps:
and [MENTION=102386]aai[/MENTION] with matte bronze and OEM part # PTR18-35092 caps:
Great photos! Thank you again very much for ordering, and thanks for your excellent comparison photos. They really help illustrate the difference in stance between OEM and the 17x8" Konig Countersteer Type X. Your 4Runner looks great too!
Thanks again for ordering! You were great to work with too!
We do offer matching center caps. Please see my post above.
see my post above on this page
Thanks [MENTION=100559]Kiruxa[/MENTION]T4 - I reposted your photos. :)
You can see how different they look depending on the light.
It was a pleasure working with you too! Thank you again very, very much. I am glad you like your new wheels. Your 4Runner came out awesome. Very unique. I just don't seem to see as many Barcelona Red T4Rs as I'd like. Seeing yours makes me want one. :)
Thank you very much Mike! It was a real pleasure getting to meet you and getting to talk for a bit. I can't want to see your 4Runner with the new wheels installed!
Huge thanks to Dustin at FN Wheels. He was such a pleasure to work with. Definitely stoked to be a part of the FN Wheels family.
Hi guys,
I'm thinking about pulling the trigger on a set of 17'' Countersteer Type X rims for my 2015 TE. The only reservation I have is the relatively extensive negative offset (-10mm) compared to Toyota's stock which could place additional stress on the entire suspension. I'm not an expert on the subject and was wondering if someone here could tell me if I have a reason for concern.
Thank you.
Cheers. :cheers:
Hi guys,
Thank you.
Cheers. :cheers:
Yeah it's additional stress. But seriously pretty minor, it's an inch offset from stock.
BillM777
