FS: 17x8 Konig CounterSteer Type X - CORONA, CA
My next purchase right here, damn I'm going to go broke if I stay on this forum!!!
Hi Jeff!
I'm glad you like the Five Stars! The 17x8.5" Five Stars have been out for a little while now (a little less than a year), but we haven't added them to our website yet. Here are the specs:
FN Wheels Five Star
Diameter: 17"
Width: 8.5"
Offset: -6mm
Backspacing: 4.5"
Load rating: 955KG (2,100lbs+)
Weight: 22lbs (approximate)
Certification: JWL-T, VIA, SAE J-2530, DOT approved
Colors: Anthracite light gunmetal, matte black and matte bronze
Toyota specifics: 106mm hub centric for Toyota hubs, lug holes drilled for 12mm Toyota wheel studs for a snug fit, and center machined to accept flat snap-in OEM TRD center cap.
Price: $899 for a set of four including shipping anywhere within the contiguous 48 states (please contact us for a quote if you are outside the contiguous 48).
fnwheels-albums-fn+wheels+five+star+1785-picture33102-fn-wheels-five-star-matte-black-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33103-fn-wheels-five-star-matte-black-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33100-fn-wheels-five-star-anthracite-light-gunmetal-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33101-fn-wheels-five-star-anthracite-light-gunmetal-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33098-fn-wheels-five-star-matte-bronze-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fnwheels-albums-fn+wheels+five+star+1785-picture33099-fn-wheels-five-star-matte-bronze-diameter-17-width-8-5-offset-6mm-backspacing-4-5-load-rating-955kg-2-100lbs-weight-22lbs-approximate-certification-jwl-t-via-sae-j-2530-dot-approved-toyota-specifics-106mm-hub-centric-toyota-hubs-lug-holes-drilled-12mm-toyota-wheel-studs-snug-fit-center-machined-accept-flat-snap-oem-trd-center-cap.jpg~original
fivestar1-Edit_zpsee5cb5fe.jpg~original
which konig's will fit a 2016 4runner trail stock height with no rubbing on stock tire size? looking at the countersteers with -10mm offset or -6mm offset five stars.
yes they should (but this is dependent on a number of variables like alignment, wheel spacers, tire size, etc.) For the record, the wheel doesn't rub, the tire does, although i wasnt sure if thats what you were asking
Will use 265/70/17 as the tire. Which rim could I put on so tire doesn't rub? No wheel spacers or lift. Stock suspension/height. Just want wider wheels.
Who's truck is this? And what color gunmetal is that on his truck? the lighter one or the darker one?
It looks really clean and i am in the process of negotiating a set of anthracite light gunmetal with a forum member and i want to know if this is the anthracite light gunmetal, bc i really like the way it looks.
That's the darker gunmetal
Sent from my Nexus 6P using Tapatalk
Considering 17" countersteer type x in bronze. I think it would look good with salsa red from what I've seen on the forum. Do you ship to Alaska? I'll be moving there soon since I'm military.
Thanks Dustin! Got my wheels on yesterday. LOVE EM!
Where are Konig Countersteer Type X made? because i cant find them on konig website, can anyone snap some pics on the back so I can read it?
Ambrose67
