FS: 1996 4x4 Limited Part out Desert Dune 240k (Norfolk VA)
Interested in the driver's side power mirror if it is in good condition.
I need to double check my color, but it looks identical. Let me know a price shipped to 70118.
Yours, I'll get you photos and a price this weekend.
More photos:
Rob, based on your photos, I could use the following parts:
- upper grab handle, tan
- transfer case shift knob, J pattern
- fuse panel cover, tan
- retaining clip from bottom left rear of center console, tan
- retaining clip from lower front of driver's side door, tan
- do you have the tools for the spare tire (stored under the right rear passenger seat)?
- I could use this retaining clip circled here
- I need the bracket and bolt which retains the rear brake line fastened to the rear axle, located slightly higher than what I circled here
Rob, here is an additional photo of the bracket and bolts from the rear axle to the rear brake line {I could also use a 17mm bolt, washer and nut from the panhard/trac bar}:
I'll check the tools Sunday. Not sure on the pan hard bolts as I still need it to roll as safely as possible with one lower link already rotted out I'm hesitant to remove other connections just for a bolt. Everything else should be fine. When I get it Sunday I will get you a price.
I guess never mind on the tranny if it has issues lol but I do need a seat bottom to replace my drivers seat bottom the pass side look good let me know I don't know who's has first one it but I could pick it up tomorrow after work
Grille to 41017? If its chrome.
Grille is not form sale currently. I'm doing a satoshi and will be using it. My 97 will be when I'm done, but someone else already has 'dibs'. You're second in line
You going to keep the tranny if not how much I will pick it up. Just like to have spare parts...
I was planning on pulling the VB from it. If you want the rest you're welcome to it. Send me a pm with an offer.. Thanks
The seats are going complete to Doc. They are pretty rough anyway
What shape is the passenger bumper end in?
Also how much for the drivers side front bumper flare?
Need shipped to 16232 in pa.
Passenger side is a bit rusted. Center is shot and driver looks okay.
I'm going to try and keep all the flares complete, if something changes I'll let you know.
