FS: 1st Gen, 1985 4runner V8 Rock Crawler $8000, Mojave, Ca
Prototypemech
This is a one of a kind rock-crawler. Built on a 1985 4runner, this SUV has a smog-legal (refereed) Ford Mustang engine and transmission. This truck has seen its share of dirt, rocks, mud, sand, and what ever else I could throw at it. It ran a 15.9 sec 1/4 mile at LACR, get 15-17MPG hwy and I was commuting this truck 100 miles a day until I crushed my foot and broke many bones and now driving manual transmission is a pain. So I'm reluctantly selling it. This truck has about $20,000 worth of parts installed on it with folders of receipts to prove it. This truck is not for everyone; it is for someone who wants a street legal toy who knows how to maintain a vehicle.
The good:
1985 Toyota 4runner (Highly Modified) 212,000 miles.
Engine - 1989 Ford Mustang EFI 5.0 (302) 225hp/300lbft torque
-Gasket Matched Upper and lower intake manifolds
-Scorpion 1.6:1 Aluminum Roller rockers
-Factory Roller Lifters
-Advanced Adapters Slick-fit headers
-1994 ford mustang timing chain cover, waterpump, w/p pulley, and crankshaft pulley.
-1994 Ford Mustang G3 135 amp alternator
-Factory Smog Pump
-Ford motorsport chrome valve covers
-Relocated engine accessories
-2 1/4" dual exhaust
-Dual 2 chamber flowmaster mufflers.
-K&N airfilter
-North West Offroad 4-core brass radiator
Power steering
-Stock Toyota steering box with Pure Motorsport AN6 fittings
-1975 Ford Econoline Saginaw power steering pump
-Gotta Show braided stainless steel power steering hoses
Transmission - Borg Warner WC T-5 (5 Speed)
-Advance Adapters Adapter to toyota transmission
-Centerforce stage 2 clutch and pressure plate
-Ford motorsports steel throw out bearing retainer
Transfer Case
-Marlin 4.70 Gears and Dual Shifter
-V6 23 spline input shaft
-Front Range Offroad Dual T-case shifter
Tires - 315/75/16 BF Goodrich All Terrains 20% remaining
Wheels - Alcoa 16" aluminum rims
Front Axle
-Toyota 8" V6 third member w/4.88 Genuine Gears and Detroit full-case Soft Locker
-Heavy duty axle shaft seals from Marlin Crawler
-IFS Vented front disc brakes
Rear Axle
-Isuzu Rodeo Dana 44 w/ Disc Brakes and Trac-loc
-4.88 U.S. gears
-Dana 44 to Toyota driveshaft adapter flange
Bumpers - Smittybilt Double Tube front, Home made nerfbars and rear bumper
Lift
-Rough Country 3 1/2" front springs and 1 1/2" shackles
-Northwest off-road 3 1/2" rear springs and 1 1/2" shackles
-1" aluminum body lift.
Winch
-Ramsey 6000 Lb
-Custom winch mount
CB Radio, Autometer Guages, Tilton clutch master cylinder, dual 10" electric radiator fans, extended braided stainless steel brake lines, Aiwa 4 speaker stereo with AUX in, sound-proofed floor, all preventitive maintenace completed 6 months ago including wheel bearings, engine oil, transmission fluid, transfercase fluid, and differential oil, plugs, wires, O2 sensors, etc.
The bad:
-A/C not installed, although I made room for an A/C compressor, evap, and condensor if the next owner feels like installing one.
-Heater works but its marginal. Good enough to defrost the window but you dont feel a blow-torch of heat like my F-350.
-This truck has been on its side. All damage was repaired except for minor sheetmetal damage.
-Body has its share of dings and dents. All are easy bondo-jobs.
-Cab Roof is primered and needs top-coat.
-Minor rust inside the A-pillars. Its not a big problem but full-disclosure.
-Tires are getting low on rubber. Probably good for another year or two.
-Window was replaced a few years ago and the chrome trim never went back on.
-Leaks a minor amount of oil out of the left valve cover.
Jhunt
