FS: 1st Gen 1987 4Runner $2500 Olathe CO
torynich
1987 Toyota 4 Runner
4 cyl EFI, 5-speed
4" Lift
4.88 gears f/r
New 33" BFG Mud Terrains
New 15x10 Black Steel Rims
HID lights
Downey Cold Air Induction
Headers, Flowmaster, 2.5" Exhaust
Grant GT Steering Wheel
Stainless Steel Braided Brake Lines
Upgraded Slotted Rotors...Newer Brakes
Rust Free!!! Hard to find in this generation 4Runner!
I bought this Runner with a sick engine. I have removed the original engine and sourced a replacement engine that still needs to be installed. This engine has in the last 2000 miles had the timing chain, oil pump, and head gasket replaced. Also installed an Enginebuilder crawler cam, newer style intake plenum, 7mge throttle body and air flow meter. Has the chevy alternator bracket or stock toyota alternator bracket so you can choose which way you want to go. Clutch replaced 5000 miles ago. New starter, motor mounts, oxygen sensor, misc other stuff. The injectors were recently cleaned and flow matched. Many of the engine parts have been powdercoated (silver vein on the brackets and such and prismatic black on the rocker cover and induction plenum). Newer radiator and battery. I am moving and am losing my garage space so I am selling as-is...needs motor installed. Has an S-Title but everything is in good shape. The interior is in ok shape...minor staining but should clean up nicely, just havnt gotten around to cleaning that part up yet since I was concentrating on the motor, all the carpet is there. Has a back seat. Has a factory tachometer. The rear window works like it should. Install this 22re or better yet - now is the perfect time for a motor swap!!!
$2500. Also interested in trades, so let me know what you have. Text 970-209-seven three three six
Go here for pics since I cant seem to figure out how to post them:
1987 Toyota 4Runner
alexaturner
