FS 1st Gen Red 86 4runner SR5 5 speed $6500.00, Tucson, AZ
dart_man440
FS 1st Gen Red 86 4runner SR5 5 speed $6000.00, Tucson, AZ
Lowered price to $6000.00.
I have up for sale, a red with gray interior, 86 4runner SR5 4x4, 5 speed. Vehicle is in good condition. Vehicle starts on the first try and runs great. I purchased this 4runner a little over a year ago and have been fixing it little by little, unfortunately am in the process of buying a home and I need to sell. The vehicle has a 5" lift and newer wheels with BF Goodrich tires, it also has after market front and rear bumpers.
Asking $6000.00 Vehicle is located in Tucson, Arizona
The original mileage on the vehicle is 317,774 miles, however, the 22RE motor was replaced with another motor. The new motor was an original 86
4runnner, 180k motor, the motor was gone through and was freshened up with a new head, cam, new timing chain, timing gears and tensioner, new timing chain cover, new oil and water pump, new head gasket, the injectors were rebuilt, all new "O" rings and gaskets. Also a new TPS and new hoses (heater, and bypass), new battery and idler pulley bearing. It is an original a/c vehicle, non functioning at the moment, but all components are there, it will need to be recharged or converted.
New clutch, resurfaced fly wheel, throw-out bearing and new slave cylinder and new motor mounts.
The front end was also gone through, new upper and lower ball joints, new cv joints, rotors, pads and rebuilt calipers with new brake hoses, it has Warn manual hubs and new front and rear shocks. The steering gear box was also replaced. No leaks of any kind at all.
The body is in good condition and has an older paint job, the paint job was done in Toyota red, not the greatest but is presentable. I purchased the vehicle after the paint job was done, I could not find any major rust, the floor pans are solid, the driver rear wheel well is showing signs of possible rust, due to a crack in the paint.
The interior is original, it has the Inclinometer with the tach speedo. Original moon roof vehicle. It has after market Grant steering wheel, including original. The upholstery and carpet will need to be redone but they are presentable for a 30 yr vehicle. The rear panels are present, however, the pockets and doors are missing.
With the purchase of the vehicle you will also get the original motor, a spare transmission, transfer case, front and rear differentials (From the 180k vehicle) and other misc parts.
I can send as many photos as you like, just send me your e-mail. I have tried to described the vehicle to the best of my knowledge, let me know if you have any questions. thank you,
Vehicle is for sale locally and you can see more pictures on the original add. 86 Toyota 4runner 4x4 SR5
Thank you for the PMs, as requested, a few more photos!
A few more,
A few more,
three morons asking “is this for sale?” in a nearly seven year old thread, where the OP hasn’t posted on the forum anywhere other than in this thread.
