FS: 3rd/4th/5th Gen Rear Differential Relocate Kit, $40, Free Shipping
Berty_K
Member
I’m selling a rear differential breather kit for our trucks. This kit relocates the breather into the engine bay near the other breathers. There are two reasons you would want to do this:
  1. You drive in deep water: if you’re on a trail and your rear differential becomes submerged, the sudden cooling of the differential causes the pressure in the housing to drop. Water gets sucked into your housing, mixes with the gear oil, and damages your differential.
  2. Your breather doesn’t work anymore: If you have an old or rusted breather, there’s a good chance it is no longer working. If the breather can’t release pressure and oil gets pushed out of the differential seals, causing premature wear.
This is a “beginner friendly” DIY, so no need to be intimidated! My instructions (provided here) will walk you through the entire process from start to finish. I’ll also provide my contact information for you to reach out if any issues come up.
Kit cost is $40 shipped anywhere in the US. Payment via Paypal, Venmo, or Zelle. All components are manufactured in the USA and are high quality.
  • 15 feet low pressure fuel line
  • 1 male brass barb (Threads into rear differential)
  • Breather assembly (90 micron nickel-plated steel breather and female brass barb, assembled with teflon tape)
  • 2 stainless steel worm drive clamps
  • 1 galvanized steel loop clamp
  • M6 locknut
  • 10 zip ties
  • Instructions (also attached to this post)
y4mtoUJg0hKtfQ4Qy1E4-Kwc2ySbHbu1fKVUwh6N7swwmDA-X1D1j8Y5pcFypRmGWtjjp4jv5Lxdk_JcD5HT6RKdzaWxMk1jVLhPIqboZG_1XR1KWSVzuY3xuARMDKVMsU-bUwOGw1ZePBtrm7JJ2EZEPY_b_s6oTWGbSr_LNsp2CGaEnQp6Y27aXJ2EhFoeWHt
Items you will need:
  • 14 mm wrench or deep socket
  • 10 mm wrench or socket
  • ½ inch wrench or crescent wrench
  • Snips or scissors
  • (Optional) PB Blaster/penetrant
  • (Optional) Jack, Jack stand, Wheel Chocks
Compatible vehicles:
  • 3rd, 4th, 5th gen 4Runner rear differential
  • FJ Cruiser rear differential
Instructions:
y4mVanIBS8J57lFulZrWVmx2Zx35-mTIpXO7a3vLoP9RqEt9669mSABk-3J6oLtk3q9ugiPHxRCAC15ejm6gkAMTliqDKSd3IqhGeT5TI7hR3uGbJ4FFnY3pWhe_wsaSQ2SSA3ummkaOjkZc2A8ByRMRt2vSv-4OWKdbfOtfEXEPZl-9lOST4BX5LVovDGItkn2
y4mAp2y0X6P_Yzz8yOaNT17L4rD9UGN7hTwTGcFshKug1jYvuvmvwPZrn2EzZ66T7jC_yNPbqBLevNGCB8ZgD-OnRpDJVs2LgcYBnVcZaHcj3h89c6xVUmTc0fOZKF5YWNsiatA4nL47J6Z7AnqbmT450Ii82WtDR_T65c1-DlZSYg95wc-E-CP0JI0bZEqsArw
Jhunt
