FS - 3rd Gen Center Console Auxiliary Switch Panel- San Diego, CA
diy_overlanders
official vendor
uc
Doing a Center Console Upgrade on a '96-'98 4Runner? Or just looking to add some additional auxiliary switches to your '99-'02 center console?
uc
3D printed CF-ABS 4 bank auxiliary switch panel that go into the drivers side cubbyhole in the center console.
Choose from:
1) OEM Center Console Switch Relocation w/ 2 additional Full-Size Contura Style Rocker Switch blanks (2 OEM Switch Openings, 2 1.45"x.83" openings). For Doing a Center Console Upgrade on '96-'98 4Runners.
- OR -
2) 4 Full-Size Contura Style Rocker Switch Blanks (4, 1.45"x.83" openings)
NOTE: Switch Blank Openings are slightly under sized to insure a tight fit of Switches. Not all Rocker Switches are the exact same size, so it may require some filing of the opening to achieve a custom fit.
$24.99 + 5.00 S/H available at the DIY Overlanders Etsy Shop
How does this attach inside the cubby?
Sent from my SM-N975U using Tapatalk
It's sized to fit in the Cubby box opening (thats mounted in the center console) and its thickness of the switch panel allows it to fit between the Cubby and Black trim panel that cover the ebrake & shifter area. The Black trim panel essentially holds it in place and makes for an easy install :thumb:
Tx470
