FS: 3rd Gen Custom Roof Top Rack with Lights - $1,899 Nor Cal
Foothillsflyer
New 2nd Generation 4Runner Rack for Sale! Pre wired and Lights included. Plug and play with factory rail system. No drilling required. Bolt on, Power up, and GO!
The Original Concept Motorsports 2nd Generation 4Runner Roof Top Rack.
• Fully welded construction
• No Rattling or Wind Whistling at High Speed
• Internally Wired for Lights. Under Rack Drain holes to ensure no water entrapment
• Welded expanded metal deck for easy loading and securing of loads
• 300lbs. driving / 600 lbs. static load capacity
• Powder undercoat rust inhibitor
• Black Powder final coat
• Steel support brackets
• 2 welded in 1-1/8” cross bars for all your accessory needs. Compatible with Yakima and Thule accessories
• Front light bar supports up to 30” LED off road light
• Side and Rear Light supports up to 6” LED off road lights
• Security for Your Lights - Welded tabs to Prevent Easy Un-Bolting Lights from Brackets
• No Drilling required! Uses existing 4Runner OEM Rack Rails and body for rack supports (no mounting holes)
• Designed and Manufactured in Northern California by Concept Motorsports
Rack Lighting -
The Original Zeus dual row line of light bars are perfect for the budget minded individual. These lights are similar to many of those seen on the market with a couple minor changes. The same shell is used for the outside of the light as many others have done. The motherboards have been enhanced with a built in relay to ensure the integrity of the lights should a power spike / surge be encountered. The lights have also been upgraded to a 12 degree beam pattern allowing for a much longer throw of light and a clean fade so less shadowing is encountered.
30 Inch Front Rack Light:
• - Output Lumens: 12,000
• - Output Power: 1800W
• - Operating Voltage: 12V DC
• - Waterproof rate: IP 68
• - 60pc 3w CREE LEDs
• - Housing Color: Black
• - Color Temperature: 6000K
• - Housing Material: Aluminum
• - Lens material: Hardened Glass
• - Mounting Bracket: Aluminum
• - Dimensions: 33"(L)x3.5"(H )x3"(D)
6 Inch Side Flood Lights & 6 Inch Rear Spot Light:
• Output Lumens: 3,200
• Output Power: 36W
• Operating Voltage: 12V DC
• Waterproof rate: IP 68
• 12pc 3w CREE LED's
• Housing Color: Black
• Color Temperature: 6000K
• Housing Material: Aluminum
• Lens material: Hardened Glass
• Mounting Bracket: Aluminum
• Dimensions: 7.5"(L)x3.5"(H )x3"(D)
Due to Size and Weight this item is best suited for local Pick up. PM Questions.
Thank you
workingwheelswnc
