FS - 3rd Gen DIY Drawer System - San Diego, CA
diy_overlanders
official vendor
uc
YouTube
INTRODUCTORY PRICE of $1499 for Textured HDPE and $1549 for Matte Finish HDPE (plus Free Shipping***) for the First 10 orders! 3 left at this price!!!
MSRP (starting at) - $1749 (+100 Flat Rate Shipping***, No Sales Tax)
DIY Overlanders’ BackCountry Drawer System -
This DIY Double Drawer System Kit was engineered for the true Overlanding & Offroad crowd that wants more from their cargo area storage solution. The customizable kit comes complete with all of the quality components pre-drilled/milled/finished, all the necessary hardware & fasteners, as well as detailed instructions so you can build it for your next adventure. Open T-slot channels along the entire perimeter of the top really open the doors to a world of custom applications (although we do have more products in the works).
Designed to be durable, lightweight and extremely functional while maximizing the utilization of the cargo space; this Drawer Kit System is designed to be hard-mounted into the rear cargo area. Unlike other systems out there, we use the OEM Cargo Tie-Down bolt locations and don't require the entire cargo area carpet to be removed.
From our door step to yours, you can run this kit as is; although, we would recommend performing some final finishing work on the exposed edges of the cut plywood components prior to assembly.
Some of the Key Features:
Superior Engineering
- All CNC milled components
- Clear anodized aluminum frame construction
- Flush mount, Vibration Resistant Frame Anchors (providing the strongest 90* mechanical connection)
- Fastener free, Load Distributing Top Panels
- Vehicle specific floor mounting
- Chemical Resistant HDPE exterior side panels
- Easily Assembled & Installed (with detailed, illustrated instructions*)
- Complete Unit is 127lbs Installed
All Stainless Steel Exterior Hardware
300lbs Vehicle Drawer load rating (per drawer)
- lock-in/lock-out Heavy Duty Drawer slides
13ply Semi-Gloss Baltic Birch drawers w/configurable drawer divides
9ply Semi-Gloss Baltic Birch top panels
Customizable Appearance
- Exterior panels & drawer fronts come standard with Random Textured HDPE or get the optional Smooth Matte finish (+$50)
- Drawer Fronts Hardware (Comes Standard w/ Silver Drawer Front HW & Black 550 Paracord handles)
- Color Options for Drawer Front HW: Black, Gunmetal, Red or Blue (+$5)
- Color Options for Drawer Handles: Gray, OD Green or Red (+$10)
- 550 Paracord Handles (with 20’ of paracord per handle for emergency survival needs)
uc
uc
uc
uc
uc
uc
uc
uc
uc
Some Handle and Hardware Options for Personalization:
uc
HDPE Finish Options:
uc
Visit diyoverlanders.com to learn more.
NOTE:
*This is a Kit is flat shipped and requires assembly, Estimated 5-6hr assembly time as is.
** Each kit is Built-to-Order and requires a 3-4week lead time.
*** Shipping to Contiguous 48 states
Tools Required:
- Drill
- #6 Countersink (DeWalt Part# DW2710, Bosch Part# SP506)
- #2 Phillips Drill Bit or Screwdriver
- 1/8", 5/32", 3mm & 4mm Allen Keys
- Titebond III wood glue
- 24" Trigger Clamps
Suggested Additional Tools:
- 2, 90* corner clamping Jigs
- Combination/Speed Square
Disclaimer- Please read this carefully!
*Please allow 3-4 weeks for delivery*
*Please note this an aftermarket product, to be assembled and installed by the buyer and the buyer will assume all risk*
*DIY Overlanders is not responsible for any damage to any vehicles during the installation or use of these products*
*Warranty*
DIY OVERLANDERS will warranty all products produced and distributed by DIY OVERLANDERS for the LIFETIME of the product. Products will only be warrantied if installed in accordance with DIY OVERLANDERS installation guidelines. Any modification to the original product design, functionality, or use, by said customer voids all warranty eligibility. It is the sole discretion of DIY OVERLANDERS to determine warranty eligibility. Our Limited Lifetime Warranty is effective for as long as the original retail purchaser owns the product. This warranty terminates when the original retail purchaser sells or otherwise transfers the product to any other person.
DIY OVERLANDERS reserves the right to remedy defects in workmanship or materials in one of two ways.
1. DIY Overlanders will issue replacement components to the customer that it deems defective or inconsistent with the quality of it’s brand.
2. DIY Overlanders will elect to issue the customer a full or partial refund for the defects or damages of the product.
This warranty does not cover defects caused by normal wear and tear, rust, scratches, accidents, or products used for racing/competition. This warranty does not cover damage to the finish of powder coated or anodized products. DIY OVERLANDERS is not responsible for defects that are not in control of DIY Overlanders such as, trail damage, overloading, incorrect assembly or poor maintenance practices.
*Shipping Policy*
We are unable to control environments and conditions subject to our product during the shipping process, so should it arrive damaged do the following:
  1. 1 - DO NOT ACCEPT YOUR DELIVERY without taking note of any damage that might have occurred on the delivery form. Shipping companies will not fulfill an insurance claim without the damage being noted by the customer. We cannot be held responsible for any product, powder coat or anodization damage incurred during transit. DIY Overlanders will facilitate a claim, on the customers behalf with the carrier, but it is subject to the conditions listed above being met.
  • 2 - IF the damage is so severe that it is obvious the product inside has been damaged, do not sign for the item and refuse your delivery. If you sign for the package the shipping company will view it as rightfully yours and that you have accepted it AS IS.
  • 3 - IF the damage is less severe and the goods are intact, you can make a note of the damage on the delivery slip (or electronically with the driver) before signing for the delivery. This will begin the claims process and we will help you file a claim with the shipping company, but it will be your responsibility to replace or repair the product. All awarded claim money will be sent to the customer as reimbursement for shipping damage unless a prior arrangement has been made.
*Any Returns are subject to a 25% restocking fee and the buyer is responsible for return shipping*
*By purchasing this kit, the buyer assumes all risk*
DJNutshell
