FS 3rd Gen Large Body Lifts
BODY LIFTS anyone? 9 feet of material. Cut to lengths all sizes in stock!
i've been meaning to ask if i can get a half inch lift taller in the front to offset the sagged weight from the winch + bumper up there! i need to get on making my rear bumper though, to make sure it doesn't level out from the additional weight in the back .... i'm getting getting started being serious!!
no you dont want to do that, you need to adjust your height on your front suspension to compensate for that extra weight.
does that make since?
if they are not then you have some different options, change to a heavier spring. add a spacer. go with coilovers.
but a BL higher in the front is not an option.
Yeah i figured it couldn't be that easy.... the rear will definitely be adding a bit of weight, so i'll hopefully i'll sit level again. Then i'll be ready to add the clearance back on!
:eyebrows:
Body lifts
Has anyone used your body lift with a stock front bumper? Any pics if so? Also how does the steering shaft extender hold up? On the RB body lift they seem to be metal. Very interested in purchasing, just wanting to find out what at I will need to complete this project properly and professionally. I'm looking into your 1.5" lift. Thanks again.
1 [MENTION=90789]Troutsrunner[/MENTION]
2. [MENTION=106767]GhostDog[/MENTION]
3. [MENTION=84338]LV4RUNNER[/MENTION]
4. [MENTION=107130]wickedmr2tur[/MENTION]
5. [MENTION=91423]Asaspades93[/MENTION]
6. [MENTION=101182]cobramedic15[/MENTION]
7. [MENTION=93269]griplimited[/MENTION]
8. [MENTION=61518]tmaxx13[/MENTION]
9. [MENTION=91585]calithirteen[/MENTION]
10. [MENTION=95974]lowlinkin[/MENTION]
11. [MENTION=110741]buccaneerbandit[/MENTION]
12. [MENTION=102606]infamousRNR[/MENTION]
:worthless
Lol. My bad bro. Been a crazy summer. Still not installed. Third member is leaking bad so that's taking priority. Hopefully in September I'll be set up
does the 1" need a steering spacer?
spacers, new hardware, radiator drop brackets, bumper bracket or drill holes. This it?
Steering spacer- yes
New hardware -yes
Radiator drop - yes ( I just have guys take off the lower shroud)
Burped bracket / drill holes - yes
Is that it- yes.
Email me if you would like to see the installation instructions.
seltzernator
