FS: 3rd Gen Retrofit Headlights, 250$, OR
UnderFire
Up for sale is a set of freshly retrofitted headlights, just finished them up on Friday. Some of the parts were used and some were new. They come with an extra set of bulbs and an extra relay.
The work was not flawless, but I did everything how i was supposed to be done, everything was sanded before paint, scraped the chrome off the glass, sealed with silicone and re-did the vent tubes to filter dust and keep water out.
They will not include the wiring harness, something was funky in it and caused the harness to melt on the headlight signal input side, all of the other equipment apart from the black relay has been tested and is still working.
Found a small amount of damage on one of the lenses, one of the small nubs that comes off of the front is broken in half, the break does go down into the "meat" of the lens a bit, but it appears to be 100% cosmetic.
Theretrofitsource.com sells the wiring harness for around 35$
The adjusters will not be included either.
Used parts:
OEM Koito Glass and Buckets
Morimoto Mini H1 Projectors and Shrouds
Orange Morimoto Relay (Not sure if it works)
Morimoto 3Five Ballasts
Unknown temperature bulbs
New parts:
One set for 4300K bulbs
Black relay (was new...)
230$ Shipped
If you are interested I can go into full detail about where everything came from, How all of the work was done in the retrofit, and how the harness was damaged, just shoot me a PM.
Man, not to undermine you, I'd get these in a heartbeat, just can't justify spending it when I can get a new TRS kit for 300.....
I can't tell you how many times I've been right there for PMing you about these.
I completely understand where you are coming from since some of the parts were used, but since I've got the extra money tied up in the bulbs and other misc parts, I can't really take less.
Not to mention this was really a lot of work, I probably put 6 or 7 hours into these things said and done.
I'm dropping the price 20$ atm, just found some damage I hadn't noticed on one of the lenses, one of the the little nubs that sticks off the front has half of it broken off.
Also possibly interested in Misc trades, even non-T4R stuff, electronics, video games, audio equipment, tools etc.
I'd suggest posting some pics of them running.
I would think if the cutoff is great then they are definitely worth over $300+
workingwheelswnc
