FS: 4th Gen 2007 Toyota 4Runner Sport 4x4 6 cyl, no mods - $13K OBO - NJ/NY REDUCED
greenman91
2007 Toyota 4Runner Sport with 152K miles. 6 cylinder, 4x4. Remote Start. Two keys. Clean title. No issues. Pictures are recent.
Vehicle will be professionally detailed before sale.
Work done between 140K-150K, in order:
• Professional interior detail of trim and surfaces. Carpet, seats and upholstery all deep cleaned with carpet cleaner.
• New front OEM rubber mats.
• New tires all around. https://www.tirerack.com/tires/tires.jsp?tireMake=Continental&tireModel=TerrainContact+H/T
• Replaced all spark plugs with Toyota OEM plugs. Found no oil leaks.
• Replaced serpentine belt along with water pump. New water pump is made by Denso.
• Replaced engine and cabin filters.
• Drained and refilled transmission fluid with OEM Toyota fluid. Replaced transmission filter and seal with OEM parts. Also replaced washer and torqued to specs.
• Drain and refill transfer case fluid according to specs (fluid, washers, lbs. of torque, etc).
• Drain and refill front and rear differential fluid according to specs (fluid, washers, lbs. of torque, etc).
• New stainless steel catalytic converters with Denso O2 sensors.
• New Walker stainless steel catback exhaust system (sounds stock).
• New brake pads, disks and calipers.
• New battery.
• New Denso radiator along with new antifreeze fluid and new OEM radiator cap.
• New brake lines and fluid.
• Replaced lower steering column shaft with new OEM shaft and parts.
• Replaced windshield.
• Synthetic motor oil with OEM Toyota filter replaced every 6K miles.
*no used parts were used for the above work
Check comps
I would check comps for this rig and reprice. It's a bit high in my experience of owning a couple 4th gens.
Hi! Good luck on your sale. If you want to sell quickly, please post more pics of underside of the car, especially up and around the spare tire under the car.
NVBASSJUNKIE
