If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
$250+shipping
13,500 miles on parts
(recently upgraded to Icon Coilovers in front and metal tech LT in rear)
Bilstein 5100s(24-239370) with moog FJ 4x4 springs( 81108) & KYB tophats
(currently at highest setting)
swaybar relocation blocks
Moog FJ 4x4 rear springs (81081)
How much lift roughly did you get w these
no rear billies?
How is the ride quality with the moog springs? I've heard they make it considerably stiffer...
Also, were you able to fit your 285/70s with this lift without having to do a bmc?
Did you max the caster out with UCA's by chance? If so, that is probably why.I was able to fit the 285/70/17s with this lift. All I had to do was push the fender liner forward and trim some of the front bumper and remove the front mud flaps. (all very easy to do)
Keep in mind, I have aftermarket UCAs and spidertrax spacers...not sure if that makes a difference.
