FS: 5th GEN - Ironman 4x4 Foam Cell Pro Stage 3 + Tires - South Central, PA - $2500
haptizum
This kit is brand new in the box. I also had the factory assembled the coil overs for less work. Also comes with tires and some lights as well.
Specifications
Coil overs come per-assembled (set to 3" front and rear
This Lift Kit Includes:
Front Coil Springs - (1 pair medium load 0-110lbs additional payload)
Rear Coil Springs - (1 pair medium load 0-660lbs additional payload)
45682FEC - Rear Shock Absorber - Foam Cell Pro (2)
45710FE - Front Coil Over - Foam Cell Pro (2)
UCA001FA - Pro Forge Upper Control Arms (1 pair)
1209K - Front Sway Bar Spacer Kit (one set)
PANHARD015 - Rear Adjustable Panhard Bar (1)
SBEXT006 - Rear Sway Bar Adjustable Endlinks (2)
The tires are Falken Wildpeak A/T3W in size P285 / 70R17 117T
I will also include two Ironman 4x4 3" Universal LED Light Kits With Side Shooters (each kit has two lights)
PICKUP ONLY IN THE SOUTH CENTRAL PA AREA (CUMBERLAND, DAUPHIN, YORK, LANCASTER, LEBANON, PERRY, ADAMS COUNTIES) AS WELL AS MARYLAND (FREDERICK & HAGERSTOWN) , NORTHERN VA, AND NORTHERN WV (MARTINSBURG).
$2500 CASH ONLY
Having trouble uploading photo so here is an Imgur link: https://imgur.com/gallery/ironman-4...sion-kit-5th-gen-toyota-4runner-tires-95UUzUu
brendaglores
