FS: 5th Gen Misc Parts Houston TX $120
QwikKotaTx
Misc maintenance parts for 2010 and newer. All parts are new except for oil filter and t-stat housings. $120 shipped conus. Please use email or PM.
1X AC Delco 12F46 Gas Cap
Seals/Gaskets
1X UAC RS2584 A/C O-ring Kit
1X Carlson 15392 Front Caliper Seal Kit
1X Carlson Brake Pin Boots
4X Toyota Copper Trans Oil Plug Gasket 35178-30010
1X Toyota 63251-12190 Sunroof Weatherstrip
8X Toyota 90430-12028 or 90430-12031 12MM OIL DRAIN PLUG GASKET
1X Toyota 90430-37140 gasket
2X Toyota 90301-1504 transmission O-Rings
6X Rear Diff drain plug crush seals
Bulbs/Lights
2X (1 set) Beamtech H11 LED Bulbs
Many taillight bulbs
Bolts/Screws/Plugs
1X Toyota 90341-10011 TRANSMISSION DRAIN STRAIGHT SCREW PLUG
2X Wheel studs, one front, one rear
Misc
9X Toyota 90467-08217 RADIATOR COVER CLIPS OEM
1X Gates Belt K070846
1X Gates 18336 Heater Hose
1X GMB Universal Joint
1X OEM Center Console Lid Latch
Used Parts
1X OEM Aluminum Oil Filter Housing TOYOTA 15620-31060, Used 15k miles
1X OEM Thermostat housing, used, good for flushing system
Jhunt
