FS: 2007 4Runner - Wichita KS - $8000 OBO
Sandytrean
2007 SR5 V6 4x4
Toytec 2" lift
RCI Full 1/4" aluminum skid plate kit underneath
RCI Bolt on rock sliders (full top plate and powder coated)
5 Falken AT4W LT C 275/70-17s (5k miles)
Frontrunner Roof rack
LED Light bars all around (Removed but will come with truck)
Apex Offroad Front Recovery Points
Clean title
Clean Carfax
Mechanically sound, has some cosmetic damage:
Front/Rear bumpers, rear drivers door, dent on hood and scrape on rear drivers quarter panel
Windshield damage on passenger side. 3 years old with no leaks and no obstruction of vision
Previous Owner 1 maintenance log:
Mileage: 170473
Maintenance items: Cabin air filter, plugs, oil change, diff fluid, transmission fluid, power steering fluid, coolant, serpentine belt, tensioner
Aftermarket parts installed: Cross drilled/slotted rotors (F/R), EBC pads, shims, Pentosin brake fluid, weathertech mats
Repairs: Valve cover gasket set, rebuilt calipers
Mileage: 171810
Aftermarket parts installed: New sport headlights, window tint
Repairs: Front wheel bearings, rear axle rebuild
Mileage: 173901
Maintenance: Oil change
Aftermarket parts installed: OME suspension (884 front coils, RC2.0 rear), superlift bags, RCI front, filler, transmission, transfer case, control arm skids, diff drops, spidertrax spacers, SPC upper arms, 265/70-17 BFG KO2 x5)
Repairs: Lower control arm rebuild, ball joints, sway bar bushings, tie rod end links, front sway bar end links
Mileage: 176214
Maintenance: Oil change, sylvania low/highs
Aftermarket parts installed: Frontrunner slimline rack, auxbeam bumper lights, LED backup bulbs, front light bar, rear light bar
Repairs: L/R CV axles
Mileage: 180,596
Maintenance: Oil change, air filter, cabin air filter
Aftermarket parts installed: 275/70-17 BFG KO2 A/T (10 ply)
Repair: Axle seals
Previous Owner 2:
Changed oil w/synthetic every 3000 miles
Replaced Battery October 2019
What I have done since Fall 2019:
Changed oil w/synthetic every 5000 miles/6-12 months
Changed Air filters every other oil change
Sony Head Unit w/Apple Car play (OEM radio will come with vehicle) XAV-AX1000
RCI rocksliders (powdercoated) & apex front recover points – Spring 2020
New Front Left Hub (OEM parts from Jersey Hubs - October 2020)
Replaced 1 bad coil pack with Denso part summer 2020
Mounting plates for recovery boards
Satoshi Grill Mod Spring 2021
Denso Radiator w/ Toyota fluid Summer 2023
New Battery Jan 2024
Tires/Alignment Front EBC green brake pads May 2024
Photos: Album — Postimages
worriedgild
