FS: 5th gen TRD PRO suspension $425 - MD
S54MCoupe
I've got the factory Bilstein TRD Pro suspension from my 2015 4Runner. These were taken off at 16k miles. Asking $425
Located in Annapolis, MD. NO shipping at this time.
Whats the benefit of these over sr5 suspension? Does it sit any higher in the front? Im assuming i would have to use my oem springs in the rear?
I know these will fit on a 2003 4Runner V8 but do you know exactly how much lift it will give the car in the front and rear?
It will raise the front 1'' and keep the rear the same with OEM springs. They're valved more aggressively than OEM so it handles better on road but also absorbs bumps very well off road.
I don't know what it will do to a 4th gen. But on a 5th gen it raises it 1'' in the front over stock. Rear height is dependent on the rear springs you choose. I have the oem 5th gen rear springs as well but I don't know if they are any different than a 4th gen. Sorry
Annapolis is what the post says.
It levels out the SR5 at least. not sure about the trail.
Ok. Sounds good. I'm in the Lehigh Valley Area in PA (about an hour and some change north of Philly) my SR5 is sagging like crazy in the front. Hoping this might do the trick. It is a 2011. Should be an easy plug and play right?
Philthyphilthy
