FS: 5VZ-FE Part out - Prices Listed with parts - Chesapeake, VA
robb1887
Story goes I went to go get this motor for a complete rebuild/blueprint/SCprep and caught that it had a window in the block for extra ventilation... :wtf:
The guy really wanted it gone so I got it to part out and hopefully fund the next one.
Unknown milage.
Automatic
5VZ-FE
From the looks of it, the truck spun a bearing after piston removals, unsure on overheating issues.
What I have listed is all I have. If its not listed, I do not have it.
Prices are OBO, and do NOT include shipping.
Parts:
Torque converter SOLD
Driver head (Bent valves) $100
Driver Cams $100
Engine Oil Dipstick $5
Flywheel/flexplate SOLD
Misc engine hoses (cooling/vacuum) $20
Pass head $150
Pass Cam $100
Lower intake runners $25
Upper intake runners $25
Timing belt idler pulley and bracket $15 (no play, no resistance)
Crank position sensor $15
Cam position sensor with bracket $20
Oil cooler $30
Toyota Coil packs and Aftermarket spark wires $60
Mechanical fan bearing/bracket $20
Accessory pulleys $10
Water pump & lower rad pipe $30
Alternator with brackets $100
Complete uncut engine/trans wiring harness $100
Power Steering pump/res, pulley, and brackets $SOLD
Motor mounts $50
Upper Timing Belt Inner Cover $10 (Outer is SOLD)
AC compressor $100
Throttle body $SOLD
Fuel injectors/rail/hose/spacers $100
PM sent.
Also, I hope that guy doesn't have another 3rd gen! If he does, he better make sure he doesn't put those single electrode spark plugs in!
