FS: Dobinson C59-675V rear coil springs 4th or 5th gen, Indiana
blackoutt
Selling my used for 11k miles Dobinson rear springs part number C59-675V. When I bought them they were marketed as 3" lift springs because it was assumed that 4th gens would get the same lift as 5th gens, but that assumption has since been revised and they only gave the updated number of 2-2.5" lift. The ride is great with the progressive rate and with the long travel design there's no concern with dropping a coil out of the bucket at full droop. I liked them so much I only replaced the with a slightly taller version. The coils do show normal cosmetic paint wear on the ends where they contact spring buckets, on the inside from helper air bags rubbing, and on the lighter weight coil to coil contact faces from full compression. Asking SOLD conus paypal ff.
For a 4th gen you can expect: 2.0" to 2.5" lift
For a 5th gen you can expect: 3" lift
C59-675V - Variable rate comfort option, stock rear weight, 470/470mm, 16mm wire, 157-230LB variable
Crookedcat
