FS: Dobinsons C59-302 2.5" Front Coil OC/CA
onepremiere
Less than 500 miles. Like new original box.
$150 Shipped anywhere in the US.
Located in South Orange County.
What is the spring weight? Are these for a stock front end or with a bumper and winch?
These can be used for both loaded and unloaded front ends.
Loaded: 2" of Lift
Unloaded: 2.5" of Lift
I am unloaded and got just a hair over 2.5" of lift.
C59-302 - 100-220LBS heavy load front weight, 2" lift. 395/395mm, 17mm wire, 586LB
C59-302 - Stock front end load, 2.5" lift 395/395mm, 17mm wire, 586LB
Specs are the same on the 4th Gen.
C59-302 - V6 - Stock front end load, 2.5" lift. 395/395mm, 17mm wire, 586LB
C59-302 - V6 - 100-220LBS heavy load front weight, 2" lift. 395/395mm, 17mm wire, 586LB
REE
