FS: Used Dobinsons Rear KDSS C59-723 Coils, So-Cal Vista, $200 obo
iDRiVaT4R
For Sale: Vista, CA, pickup or may meet locally. $200 obo
Looking back at my records, I may have only had these installed for 6-8 months in total.
Used Dobinsons C59-723 Rear KDSS Coils.
I'm not sure if these are sold anymore, one coil in the kit is taller to account for the KDSS lean in the 5th gen 4Runners. On the 5th gen's, the taller coil is mounted on the passenger side.
If used on 4th gen, the taller coil mounted on the driver side alleviates most, if not all the driver side lean.
From Dobinsons web site a while back....One coil is 15mm taller.
C59-723 is for stock rear end, 1.25"-1.5" lift, 420/405mm, 17mm wire, 228lb rate.
I ended up installed the C59-725 coils to give my 4runner a little more lift in the rear.
Send a DM if interested, Thank you.
youngrk
