FS: Used Toyota V6 Lockright, $175, Hesperia, Ca
J-money$$$
Part number 1620-LR
I pulled it out of the rear diff in my truck and put a spool in its place. I installed it a few years ago. Probably has around 40K miles on it. Teeth look good, can post pics if your want. Still have original box and paper work.
Bad: I found one of the springs was broken when I removed it. THere was just one coil broken off one spring. So it probably wouldnt effect the performance much, However spring and pin kits can be found cheap ($20) from most places that sell Lock Rights. the Pins are all in good shape.
$175. Local pickup preferred. Its in Hesperia
I never really looked much at this since I pulled it out. i just cleaned it up and took some more photos
This last photo shows some wear I did not know existed. Locker still worked fine, All i can think is this is just from its normal operation. But the teeth look a little weird here. There are a couple on each half that look like this. Look at the tooth with the oiling hole in it Shouldnt effect operation.
I would do $150 shipped on it because it looks like this.
Man I wish this was for the front diff! I'd snag this up in a heart beat! I just bought an E-locker for the rear.
Bump for a great price! Good luck with your sale!!
