The Durk had a great write up on the fan clutch replacement last year on YT; persuade him to post it here for ya.
Thank you. I will definitely checks all belts.How do your drivebelts look at the moment? The reason is they(ALT + PS) will have to be loosened to get the clutch out. Might as well replace all three if need be.
Make sure to have an in/lb torque wrench and ft/lb on hand, a 12mm regular or stubby for loosing the ALT belt and a 14mm stubby wrench for the PS. You can get the wrenches individually from NAPA, Sears, etc. The link below is for the whole metric kit.
GearWrench Stubby Wrenches — 10-Pc. Metric Set | Stubby Wrenches | Northern Tool + Equipment
Thanks in advance for the writeup. Yes, climbed to 100 deg today...Twern't no big thang, but I thought I did it on here...I'll take a look because it's getting hot and a few more FC's are gonna pop.
Thanks The Durk,
Will do the swap this weekend.
I got an OEM Aisin from partsgeek.com last summer. Very pleased. For a ten-year life mission critical part (my factory fan clutch failed going into the Lincoln Tunnel, not pretty) I wanted a good one.
I'm bumping this thread since I see no point of a new one.
Durk, what were the symptoms of your fan clutch failing? I was on the GWB when I really noticed that my fan is excessively loud while accelerating when compared to other 4Runner's I've heard. I'm the original owner too, but I really can't remember if it was this loud before.
Excessively loud would mean it was locking up. Mine failed by not engaging, sending my temp gauge into the red and causing steam to start escaping from under the hood before I shut her down.
This may help you, it's from a BMW group but it applies:
Testing for a bad Fan Clutch (Sachs and Behr)
