just66horns
Hi,
I bought a 90 4 runner v6 automatic 4x4 last month for a grand. I knew I could fix it...
The ebay auction said it stalled when running cold and gave off white smoke. I got it home (towed it 500 miles) and turned the key and it runs fine, but now, I notice that on a cold morning, it runs fine for 1 mile. Then, when I hit the gas at a stoplight it can sometimes die. It will not restart for about a minute, and then I have to crank with the throttle open, and finally it catches. If I don't stall it again, it will take me wherever I want to go for the rest of the day.
Another symtom, maybe related. Also on a cold start, but continues for what seems to be too long. Overdrive will not function on the 6 mile drive home. Seems too warm weather wise and like it should be warm by the temperature gauge... all other times, the OD works fine.
Here is what I'm thinking...
The OD will not function when the engine is cold. The temperature switch (not gauge sensor, but the switch) tells the OD when the engine is warm. So, on cold starts, that same switch is also telling the fuel injection computer that the engine is cold, and floods it when I ease the peddle down. Won't restart because it is flooded, till I clear it out...
Before I get around to replacing that switch, what do you all think? Am I on the right track. I'm going to replace the switch anyway, so, this is a test for yall.
I will find it.
I will find it.
