Garmin Stealth Box
Senior Member
It is well known that lots of cars are broken in because of portable GPS units are in the plain view or suction cup on the windshield is a dead give away. The only solution is to make it hiden but also usable without the need to scramble in the glove box.
Here is my solution:
IMGA0234.jpg~original
There were few places I had in mind for my Garmin 750. One was eyeglass compartment overhead, but due to lack of sufficient space I scraped that idea. Second was rear view mirror but that would be visible from outside when car parked. My third and final choice was that empty space of a beverage holder. I had plenty of area and discrete location for my 4.3 in GPS unit. All I needed was some time, plenty of patience and some materials.
Materials
1) Sheet Aluminum
2) Low Density Foam
3) Vinyl and Fabric
4) Glue
5) Epoxy
IMGA0219.jpg~original
I started with tracing cupholders outline and making templates for bottom and top of the opening. Two aluminum sheets cut and checked for fit was the foundation of this project. Aluminum bends easily therefore making box for 3x5 unit was piece of cake. I used epoxy to bond parts together.
IMGA0218.jpg~original
Once top and bottom were ready I measured the depth of cup holder and used pine spacers to get right level at the top.
IMGA0224.jpg~original
Foam is added to give the box its shape.
Then hinges added. Lid is made of 2 identical sheets of Al with hinges secured in between. Once I was happy with results I glued in some soft cloth and foam for the GPS box and vinyl for lid and rest of the holder.
IMGA0229.jpg~original
That is all there is to it. When GPS in use I open the lid, power the Nuvi and get on the way. Once I park
Very clever! If I leave it in the truck, I just put the Nuvi in the console with the suction mount.
Also, the rings the suction mount can put on the windshield are giveaways for the thieves, too.
I just toss mine in the glove box, and I keep a supply of windshield wipes handy to take care of that 'nasty' ring.
I have one of the larger Garmin units with the weighted base that sits on the dash.
When not in use during trips, I stow it inside the center console for short stops and bring it into wherever I am staying for overnight stops.
Otherwise it is in my house in a small tool bag I bought at Harbor Freight. The unit and it's accessories fit nicely in that bag.
Also have room in the bag for the old fashioned backup I bring for the GPS (ie maps).
<<<< said:
... There were few places I had in mind for my Garmin 750...
You make it sound easy. That is good work.
Question about the 750 reception. Does it have an internal antenna (not the flip-up?) How is the accuracy in that location?
Re: Re: Garmin Stealth Box
It is very accurate but reception is crapshoot in bad weather. when you get heavy rains you get no reception at all. In decent weather it works flawlessly.
Re: Re: Re: Garmin Stealth Box
700 series have internal antennae, works just as well as the flip up, without the clutter and looks much better.
750 has had good reception for me in heavy rain, might just be location.
To those thinking about buying, update to the latest firmware, it fixes a satellite issue in the 700 series. I went from 0 bars at boot without the update to a full reception within 10 seconds with update. Also i hear the 2009 (naming for the latest map, to release in 2008) Maps are coming out at the end of this month, so wait till that comes out before you buy.
NICE!!
Very nice. You did a great job.
I have a Nuvi 350 and i put my GPS in the center gauge cluster.
It fits perfect and dosnt move.
