Gas Mileage associated with faulty diodes in the alternator?
nissanh
Senior Member
Something good took place in my 4runner.
Back story.....I own the 97 4runner since 2010 and seen 21 MPG on highways and about 15 to 17 in city while I lived in NV. Then moved to deep south and noted MPG dropping to 16 MPG on highways and 12 MPG in city. Been like that for years no matter with new tires (been using 265/75 16 A/T throughout), 32 PSI, new denso front and rear O2 sensors, different fuel brands, cleaned injectors, new plugs, new coils (OEM), new plug wires OEM, new air filters OEM, etc.,... no brake drag.. it is best at 16.5 with 65 MPH cruise. at 70+ MPH speeds it is always 15.5 mpg!
Now, to the story. I rebuild the oem alternator with new oem brushes and oem bearings. I started hearing a humming noise coming from the alternator. I rechecked the bearings (removed and reinstalled bearings making sure no excessive tightness etc.,), the noise was still there. and then after a few months later the alternator stopped charging the battery. I took it apart and inspected the diodes and noticed 1 was ripped open. Then tested the diodes with an multimeter with diode testing setting. Out of 3 positive diodes 2 were bad (total 6 diodes 3 + and 3 -). Couldn't locate an OEM diode kit, purchased a diode kit from ebay (made in China). Put all together and did 212 miles with 12 gallons! I was shocked to notice 17.5 mpg. This 212 miles comprised of 30 miles city driving, windy hill driving 40 miles and rest 72 mph cruise. I also noticed no more humming noise from the alternator!
I'll continue to monitor the mpg and will report back, but seeing 17.5 mpg in this 4runner after 15 or so years later.... is like winning a lottery for me!
I think there was a one faulty diode for the past many years causing an unwanted magnetic field in the stator that puts a drag on the engine thereby lowering the mpg. Once the 2nd diode went bad, I noticed the voltage drop, making me to get the diodes replaced.
Also see this video posted by Scanner Danner:
youngrk
