JAKE06 said:What are real world gas mileage figures for the 05 4R with the V8 and V6 with 4WD? I will be in the market for a 06 4R 4WD V8 and I assume the 05 has similar gas mileage numbers. Thanks
adventureman73 said:
\JungleJim said:I agree with one of the posts above.....do a search yourself. There are some people with V8's that can't get more than 15 mpg and some V6's that average 22 mpg. There are just too many variables to get an exact number.
If you are on the low end with a V8, or the high end with a V6, you will spend/save more than $200/year.
If mpg is a main concern....I suggest that you don't get a 4Runner.
JAKE06 said:\
No, never said it was a main concern just wondering if the V6 engine gets significantly better gas mileage than the V8...........I see that it does not. I will be trading in a 04 Titan which gets 13-15 mpg.......so the V8 4runner will be an improvement in gas mileage. Thanks.
fo'runner said:I have one question for you. Why do you want to trade the Titan for a 4Runner. You can lift the Titan up in the air for that go get'em look. The 4Runner can't be lifted high enough to get through a big mud puddle. If you are looking for mileage; then perhaps you should consider the hybrid Highlander. You had the best, large pickup in its class in the Nissian Titan in my opinion!
JAKE06 said:however with the re-design on the 06...[/B]
adventureman73 said:I can't see a lot of difference between the 03-05 and the 06...or is that just me?
