gaterose build thread
Interesting. Was considering either the Gobi or Baja to replace the sport ed rack. Amazing how the mods I've done so far have brought down the mpg as much as it has (sitting higher, bigger tires). CBI informed me this morning my rear bumper w/ swingout has shipped. That's 190 lbs more I'll be adding, but unsure of any wind resistance...probably the CB antenna I'll be mounting on there will take it down another 1 mpg.
Guess I need to start one of these build threads. I'll include a disclaimer for legal protection. :D
yo!
a set of enkei "port installed" 18's (fj cruiser) just popped up in my area for $350 and i've been scowering everywhere for sequoia 17's with no luck. at the same time, some 90% tread silent armors 275/65/18 just popped up for $400.
im assuming you have your spare mounted in the factory location?
i know you have 265's but do you forsee a problem stuffing a 275/65/18 in the stock location?
I don't think people have problems fitting the 275s under there, I think that is the cut off though.
Since this thread is getting bumped, I may as well include this picture I took yesterday... Nothing spectacular, but I like pics ;):
Thanks!
I forgot to add that I ordered some new front swaybar links (the Deeza ones as shown in talonjade's thread here recently) as well as some energy suspension LCA bushings (thanks for the writeup ZachAttack). Hopefully I can get those on this week and see some difference in handling.
I'm also going to try to put on the FJ rear springs that have been sitting in my garage for 3 months. I got some OW coils during the closeout and have been trying to make up my mind which ones I want to use, and I think I'm gonna stick with FJ until I decide to put 275s (or 285s?) on again.
you reminded me that i need to scope out my sway bar on my 4Runner. i looked at those pics i think you posted in the sway bar disco thread and i still dont think it would be an issue running with no end links.
energy suspension makes good bushing, ran those on my 2500HD
Little update...
I think I'm gonna use this smoke plastidip to coat my wheels.. for now. I'd like to have them done by someone who knows what they're doing but this will work.
I only did one so far, but I like it a lot from afar
but up close the texture isn't as smooth as I'd like
I finished up my new sub box but still have to deal with the gap from the double decker and get a backpack & tool bag for the gear & tools I like to carry.
edit- I also got my new LCA bushings & sway bar links but haven't had time to deal with it
im digging the smoke. does it coat evenly? the bit about "apply more for darker coats" made me think it might be hard to match from wheel to wheel if the coats weren't exactly even.
It is a bit difficult to see how thick it is... I just tried to do two even thorough coats. It says to spray coats thick enough so that it appears glossy/wet, with 30 min between coats. I thought these pics would show the the texture better. I'll have to try to get better shots another time to show what I'm talking about.
i wish my cargo area was so clean. mine is piled up to the window with tools and baby stroller.
Hahaha I just said that I redid the cargo area! I had to clean it out for that, none of the carpet was in there before the makeover. It will have a couple of bags of tools/gear and random junk again very soon, just as it did before yesterday.
For some reason I like the double decker thing.
Do you use it? I've only used mine once and it didn't work well for the stuff I was trying to carry.. I could've made this work with the double decker but I didn't and then it was too late when I thought about changing it.
D'Angelo
