Gear oil conundrum
StreetCreeper
Ok I've searched a good bit and the results have been a bit conflicted. So I'll ask the audience.
I'm running right up on 369,000 miles and will soon be swapping out the oil in the diffs and transfer case. I know a lot of guys use the fancy synthetics and that's great, but I don't have the cash to drop on synthetics, plus I don't want anything to start leaking since I'm a "high mileage" guy. I figure if it made it to nearly 400,000 miles without synthetic oil—I'll just go ahead and stick with old fashioned dinosaur juice.
So my main question is, can I run the more common 80-90 conventional in all three (diffs & transfer) without issue? Or is there some reason that I need to stick to 75-90 which is hard to find in conventional.
I know I'm going against the grain here as most people seem to use 75-90 synthetics, but again, I have a long list of maintence things to get through and need to save cash where I safely can.
Thoughts?
Your location is listed as "The land of fruits and nuts...". Whats the weather like there? If you have a mild climate, I'd run the 80-90w. If it gets cold, then I might be more picky and stick with the recommended weight.
California...pretty mild here in the Central Valley. Typically runs from a high of 105-110 in the summer, down to around a nightime low of 30 in the winter.
Honestly I'd just get some Valvoline 75w-90 conventional for all three. It can be found at Autozone, AA, Oreilys, Walmart, etc. 80w-90 is pretty prevalent at the locations mentioned as well if you want such for the rear.
Make sure that the fill plug for all three will come out before draining it. Don't forget new crush washers.
Also make sure you rear breather is working well. If in question, replace it.
Interesting! Admittedly I have not gone inside anywhere searching for conventional 75-90 as I'm just now formulating my plan of attack for the 1st of the month maintenance bonanza. I just assumed since I haven't really found it online, that it was not very common. I kept seeing 80-90 everywhere.
INDEED! I have learned that as well. One of those little details that if not followed—will bite you in the ass one day. And I'll be sourcing crush washers from the dealer. I'm guessing $4-5 from the local dealer and $1.50 online....at least that was what I paid last for transmission crush washer.
Also make sure you rear breather is working well. If in question, replace it. Good thinking since I'm already down there. I might just run an extended breather while I'm at it in fact.
Just a heads up that I replaced the oil in all three of my diffs with synthetic at 180k and within a month the center diff started leaking out of the rear seal. At this point I think I agree with the above recommendation to go with conventional.
BillM777
