Gen 3 starts and dies...
browebb
I have a issue with my 96 , Limited, 3.4 auto 4x4. It will start but dies as soon as it starts. I have studied the other threads on this but have not seen an answer. fairly new to the forum so I might have missed what I am looking for. I did this one time before and then it started running fine. Now it is doing it again. I did have the EFI relay checked out and it seems to be okay but I am not sure what sends a signal to that relay or if the fuel pump might be the issue. I have not had this 4R very long so I am new to the details of it.
It almost seems like there might be a electrical issue or maybe a sensor that is shutting it down as soon as it gets fired off. When it was running is was getting great gas mileage ( about 18.5) and had no symptoms of any problems, but I have never seen a bad fuel pump come and go.
Thanks for any help you guys might be able to send my way....This forum is great. More info here than anyone could pour through......
Do you have a multimeter? Can you check your alternator? It starts, so it should not be the battery. Any lights on the dash?
AndiGarage
