General maintainace on my own!
uhrlag
Need to know how to fix a directional light, it blinks too fast and I think it needs to be replaced.
Windshield washers don't work, and I lost the panal that shows what fuse to replace.
It's a 2005 4 runner, can anyone help?
When the turn signal is flashing quickly, it usually means one of the bulbs is bad. The Owners Manual actually has a pretty good section about the outside lights, with bulb part numbers and diagrams for accessing the bulbs.
There is a diagram in the back of the Owners Manual as well for the fuse panel.
If you don't have the Owners Manual, you can download one by creating an account (for free) and registerting your VIN at the Toyota Owners Web site, http://www.toyotaownersonline.com/
Required Maintenance
Hello,
I need your advice. SO far, I have like 34,000 miles on my 2006 V6 4runner.. I haven't done any maintenance yet except changing the engine/cabin air filter and oil change. Other than that, I haven't done anything.. Is there any maintenance i should perform? maybe a tuneup? is it necessary? thank you!
There are quite a few things due at 30,000. Check your Maintenance Guide, or if you don't have one, go here.
Don't just ask a dealer for the "30,000 mile service", as they'll add things you don't need. Use the Maintenance Guide to tell you what should be done, and then get prices on those specific services.
It says to re-torque propeller shaft bolt and lubricate propeller shaft. Do you know fi you can do that on your own? Is it really that necessary? What will happen if you don't do these things? How much would both of these cost in a regular mechanic shop? I def not bringing to the dealer.
My dealer does those for FREE everytime i get an oil change.
