Get ready to boost!
What is a Sprint Booster?
Sprint Booster is a simple, plug-n-play part that overrides your car's factory drive-by-wire setting and eliminates your throttle lag. This in turns improves your cars acceleration by increasing the throttle response time. And by providing a quicker response time, you accelerate faster giving you a feeling of "Wow" every time you press on the gas. We Guarantee It!
How Exactly Does a Sprint Booster Work?
A Sprint Booster V3 overrides your ECU's factory setting for a "gentle" acceleration and instead gives you immediate response when you hit the pedal.
These days cars use a ECM (Electronic Control Module) rather than the old, traditional cable to open and close their throttles.
So, instead of having a throttle cable dictate how fast you take off, this ECM does it instead. So no matter how hard you push on the pedal, the ECM carefully regulates how much power to provide to the wheels.
And while this may be a more efficient way of working, it has the disappointing downside of delaying your pedals response time and acceleration.
But with a Sprint Booster V3, all that goes away. Instead, when you plug in your Sprint Booster V3 between your pedal and your ECM you bypass your factor throttle setting and replace it with instant response time. And that translates into instant ACCELERATION the moment you hit the pedal!
Check out our website and our Toyota 4Runner promotion!
YotaBoost Sprint Booster V3 Promotion
seltzernator
