Gettin high with the back window open!!
7seanc
Is there any way to keep the exhaust fumes from getting in the cab when the back window is open? Other than a smoke stack. jk. But can I end the exhaust tip somewhere else or put some kind of baffle somewhere or am I stuck with the high? I'm not down with the petrol. 87 runner 22re
I find that if I open my driver's side window all the way with the back window down, there are no fumes. With the driver's side window up, there's a lot of fumes.
Yeah that kinda works. Im looking to cut it out all together with any arangment of open windows. It may not be possible. Im going to try some things. if i find something ill post it. thanks dingman
You really should never drive with the back window down as the drag that is created by the vehicle pulls exhaust fumes in.
Simple fix: Roll up the window.
Rolling down the back window makes it not matter that my AC doesn't work, and only affects my economy by around 1MPG. It also makes my little sub sound much better. Worth it.
