Getting my winter kit up to date
sheik
This question is more about the recovery gear I should carry rather than the warm clothes and consumables.
I have a Warn Hitch Shackle, extra 3/4" Warn shackle, 3" x 20' Keeper Recovery Strap (11,000 lb), and some new 25 foot jumper cables on order. This will compliment the tow strap I already have and make me winter weather recovery ready (I think). I've never had to pull anyone out of the ditch with my F250 since we don't drive it much. But I saw plenty of people in the ditch when driving our primary vehicle, an Audi A6, which we traded off for the T4R.
So, this year I'm hoping to be able to help out anyone unfortunate enough to find their way into a ditch (or have what is needed to get us out) with our 4Runner since it will be our primary vehicle. The recovery strap I chose is rated for vehicles up to 11,000 lbs with a 22,500 lbs break strength. Is that enough? Too much? Amazon has it for $37, and the 4" x 30' (20,000/40,000) by Keeper is $83.
I've done a lot of reading on the subject but I just can't decide how much is too much and how much is just right.
Another thing, I haven't gotten under the front of the T4R to look for a good location to tow from. Again, I've done some searching but was hoping that maybe someone here knows first hand that there is at least one good spot that I can thread shackles through?
Any help or suggestions appreciated!
Nobody has used a recovery strap?
The front tow hooks look pretty beefy on mine, just need to decide what level of strength is appropriate for the recovery strap.
For those "just in case" situations where you'll need to help out (or get helped out in return) during a Sierra's snow storm:
All weather floor mats. If you're thinking of helping people, help yourself to a clean cab. I like Weathertech.
Tow/recovery strap. I got one rated at 9000 lbs. It was small and light. If 9000 lbs isn't enough to help someone out, I'm not sure I should be proceeding any further. $8.00
Chains. Chains for all 4 wheels. All terrain tires (as I do mostly highway driving) are going to be fine. But if the highways or neighborhood hits 'nasty' conditions, having them may make the difference between at-home-cooking and a night out. $55/pair
Cat litter. Sometimes just a "little" traction is enough to help someone out. If there's wheel spin on an icy patch where you can't get into a "pull" position, such as trying to help someone up a long driveway, then cat litter can help. $2.99/10 lbs
Road flares. People are going to spin out, and potentially off the side of a hill (yeah, saw that, scary as hell). Marking up and coming danger spots (white out) is a definate plus. May also stop you from getting rear ended. $.99/ea (bought 5).
Gas. Roads shut down, people plan poorly, you need to light a bonfire. A spare gallon will get someone 10 miles down the road and is fairly easy to carry. $2.599/gal
Blanket. Not everyone dresses the same or likes the temperature of your 4Runner, especially if they're in the back. A "clean" blanket helps people feel cozy. $7.99.
Gloves. A pair of semi-sturdy & waterproof (or as close as they come) gloves is going to help. You may ski and forget (BTDT) your pair, or you may need to change a tire. Not getting your hands dirty helps morale. Leather is good for dirt, but ski gloves are good for keeping warm and dry. $.99 & $5.99
Lidded container. Yes, you can just cram it into a a bag or toss everything into the back seat or even build your own enclosure. But the lid allows you to kneel at the side of a road and help change a tire or put on chains without getting your pants all wet. Plus you can cram it full of wet clothes. A 20 gallon tote runs $5.99.
Shovel. Helps bury the bodies. But also helps dig yourself and others out of the snow. $9.99
Jumper cables. Yup, absolutely, 25' is generally not only a thicker gauge but long enough so you're not fighting to angle your vehicle.
=== MISC ===
Air compressor. Allows you to air down and up. If someone has a slow leak, this may help them get home. $70 for a 30A unit.
Combine the air compressor with a $7.00 'plug' kit, and you can fix tires at the side of the road, or at a friends house.
Towels. Shop towels will let you clean off your hands or mop up messes. Soda and coffee does spill. They staunch bleeding pretty well too.
Wire cutters and pliers. Tire cables do break, and sometimes they wrap around axles. You may need to cut and pull in order to free a wheel. A leatherman isn't enough especially in cold weather.
Tire/lug nut wrench. The one you have in your car is going to be good for your car, but it may not fit all lug nuts. Combine it with the challenge of getting additional torque (mine is that lazy L shaped one), I went out and bought one that looks like a '+'. I can stand on it or kick it to get that extra 'ooomph'. $7.99
Ice scraper. You may get stuck outside, or someone else may park outside of your house overnight. Having the means to clear your windshield without sitting there for 15 minutes is "nice".
Instead of any of that, what I use is a heavy duty Nylon rope hooked to 2 hook ends. Nylon rope is from a truck stop, 4" wide, and came w/ the 2 hook ends, 1 designed to go around a 2" ball and kitty litter!
Oh yeah! forgot....Hand warmers! Just in case! for the $2 that 2 packs cost, its a good investment for your fingers and toes!
Air compressor: I have the MF-1050 which is the same as the MV50.
http://www.amazon.com/Master-Flow-M..._1?ie=UTF8&s=automotive&qid=1257095796&sr=8-1
http://www.amazon.com/Industries-MV50-SuperFlow-Hi-Compressor/dp/B000BM8RT8/ref=pd_sbs_auto_4
Flashlights: Oh yes! I actually have three for "just in case" situations.
The mini: http://www.amazon.com/Gerber-22-80107-Compact-Flashlight-Metallic/dp/B000MJPRK2
The regular one I have (which I can't find the link) is a CREE LED pushing ~220 lumens with 2 CR-123 batteries (90 min at full burn). It looks a lot like: http://www.batteryjunction.com/tactical-t20-t.html
thanks
