Glass cleaner
Several step cleaning
Stoners Glass cleaner, and then plain water, followed by a microfiber towel for drying. This method usually lasts about 4 months before I have to clean again (inside).
The frequent rainfall keeps the outsdie clean.
i tried using the Armor All wipes for inside, but they streaked all over. i've had better success w/ Windex which is a no-no. are the products mentioned good for interior or exterior?
I 2nd the Stoner's Invisible Glass,the stuff goes on easy and keeps the interior glass clean and even resistes dust for quite a while.
I find that Windex works fine but that you can't use standard, household paper towels. It is glue in the paper towels that cause streaking. I use a disposable, synthetic fiber towel from Griot's garage, many other types of towels will also work well but not household paper towels.
Cleaning Glass
Believe it or not, I have found that the best thing to use is either Windex or ArmorAll glass cleaner -- and newspaper -- yes, newspaper. It is virtually free (as you would throw it away anyhow), does a good job cleaning the glass and prevents streaking.
Left-leaning rags such as the Washington Post work especially well. It also works well for lining the bird cage.
:awais:
Re: Cleaning Glass
:awais:
My auto shop teacher taught me this 20 years ago except you can just use water which works just as well as cleaner when used with newspaper.
That said, I think cleaning with newspaper is a pain in the ass. One micro fiber cloth costs at most $1 and will last forever by just throwing it in the washer once in a while. Plus I leave the cloth in the car and it still cleans when it is dry so I have it to do a quick wipe or to wipe off some fog on the inside if I need to.
Re: Re: Cleaning Glass
i have a really good micro-fiber cloth made by 3M, which was like $4. i got it for my laptop screen, but now i may use it for my windows (which i never thought of prior).
do you initially wet the rag with water or do you use a cleaner?
Re: Re: Re: Cleaning Glass
If used with a cleaner then the cloth can be dry. If used without cleaner then you can wet one for cleaning and use a dry one to wipe and dry after. Or in a pinch it will clean decently just being used dry.
Hmm,I've always used Kirkland Premium (Costco) paper towels and with the Invisible Glass I've never had a problem with streaks and I've been using them since '99.
iFORCE said:
Please do not use Windex on film tinted windows.
That also includes any ammonia based product.
Personally, for exterior, Sprayway Glass Cleaner and Microfiber towel is what I use. Best results I've found yet.
For interior, water or a mild soapy water solution with a microfiber towel.
In regards to newspaper, I've found that printed newspaper leaves streaks because of the water based ink.
I've found the a microfiber towel really helps in not leaving streaks. Whenever I clean glass, it seems to be streak free with what I use that I stated above..
I use eagle one 20/20 cleaner and used to use a microfiber towel. However, I have been using the new paper towels out made for glass and surface that dont leave streaks. I forget what brand they are, but I buy them for general paper towel use and can use them on glass as an added bonus. You should give them a try.
