Glove compartment buzzing when open?
Senior Member
With engine off and ignition key out I get faint buzzing in glove compartment when it is open. It goes away after compartment door is closed. Does anyone notice this? It is too faint for warning door open buzz and I don't see a light in there while ignition is off. Any ideas on this sound?
Turn off the dildo before you put it in the glove box?
Are you sure that buzzing isn't the evap fan that runs a little after the car is shut off and occasionally when car is not running to vent gas fumes?
Did you do the airbag recall? I remember something about that causing a potential buzz noise.
Original airbag. Evap pump is in the back. I have high power flashlight in there and rechargable batteries were dead. Maybe I should keep it out if that is the source and it is shorting out to prevent that compartment catching on fire from bad flashlight...
DionicioLives
