Gobi Rack GROUP BUY. Stealth Rooftop Rack. Free ladder or sun roof insert
Are you interested in this group buy?
  • Total voters
    11
  • Poll closed .
Maybe Friday at the earliest on the vehicle. If not, early next week. The ladder is made, but it is currently at powder coating.
It looks really good and is extremely easy to put on.
Sea Kayak attachment
I posted this in the Gobi vs Baja thread and got no responses. I am hopeful that some of you Gobi folks could shed some insight. With the deadline for the group buy coming up along with prime kayaking season coming up I need to order something this week. Here is the original post.
Well I am trying to decide which rack to get and I would like to get some input from current owners. My problem is that the factory roof rack is too short for my kayak setup. I have a set of Yakima hully rollers and saddles and I can't get them very far apart. On my old Xterra I could get the rollers and the saddles far enough apart to not have to tie the bow or sterns down. I would like to get a full length rack to directly attach the Yakima attachments to.
I like the idea of the Baja flat rack but I also like the idea of the Gobi with the ladder. My concern on the Baja is that the bars won't be the right size for the attachments (about 1 1/8") and there won't be enough clearance under them to get the attachments on or to tie down lumber. Someone mentioned that the Gobi rack would fit the Yakima accessories. What I don't like about the Gobi is that the front bar is higher the rest of the rack which makes it harder to carry lumber up there as the boards would not be flat. The ladder on the Gobi would be nice as the wife is only 5 feet tall and it would be easier for her to get up to tie the boats down.
I don't need the mesh in either design so hopefully I can get that worked out with either manufacturer. What I need is a rack that I can attach the Yakima pieces too, and that I could put the rollers as far back and as far forward as possible. This would help ease getting the kayaks on without damage the trim over the rear wiper. The front saddles should be able to be at least as far up as the back of the sunroof and ideally would work on the front section. I don't know how the saddles would fit on the front bar of the Gobi since it is angled up. Secondary consideration would be for how easy it is to tie lumber down. I do a bit of woodworking and my favorite maple supplier is an hour away. I don't want to always have to haul the trailer down when I only need a few pieces. I don't need lights on the rack either.
Any input or suggestions would be greatly apprieciated!
Thanks,
Chris
I can't wait to see the setup with the ladder~ which may just make me have to pull the trigger despite my also not liking that the front is higher.
To me it looks so much better when the front is slightly angled down like SeattleMike's.... :hatsoff:
just sayin
Thanks! I need to make a decision on a rack soon. Hopefully it will stop raining and I can get back out in the boats. The is still well over flood stage and most of the boat launches are submerged but it would be fun to explore!
I didn't buy mine from the group buy, I called yesterday to get the ladder but they were closed. Pics are coming soon.
Ladder update... Hopefully by Thursday evening (5/26) it will be back from powdercoating and installed. With the group buys going on, the powdercoater is behind, which is the hold up.
ChrisInVermont,
Here is a response to you from Gobi
All Gobi roof rack cross bars are compatible with Yakima and Thule accessories. The cross bars are 1-1/8" round.
Actually we have a Gobi Stealth Xterra model which is substantially flat except as you mentioned for the front of the light bar which rises up approximately 1.5”. The added advantage of the light bar riser comes into play most especially when lumber is tied to the roof rack. As I’m sure you are very aware when sudden stops occur the risk of the lumber shifting forwards is high most especially when the rack is completely flat. The fact that the light bar rises 1.5” higher in the front provides a stop for the first sheet or piece of lumber and all the rest of the lumber tied to that first piece will be prevented from flying forward do to sudden stops in the case of an emergency. This is a good incentive to keep the Gobi riser in place I know because it happened to me. The alternative is our Gobi Ranger roof rack which I have attached images of and you can see in the pictures that the rear height of the roof rack is equal to the front of the light bar in essence flat or level from front to back.
either.
I understand that you don’t want the expanded metal deck and we can provide the Gobi rack with or without the mesh but I believe the mesh to be very valuable in standing on the roof rack and tying down your lumber, boxes or bags. A roof rack is only as good as its utility and leaving out the mesh on any roof rack reduces its utility by half. We have an attachment called a “Jerry Can/Cargo tie down system” which uses any part of the mesh deck as an anchor point for tie down. We designed a unique hook we call a “Delta Hook” which can be slipped into the metal deck to be used for tying down cargo or lumber or anything for that matter. I have attached pictures of the Tie down system and the Gobi stealth Xterra roof rack for your inspection. As for cross bar placement we can place them at whatever distance and at whatever point you like on the roof rack to serve your needs or leave them off altogether if you choose. I hope I have helped but if you need more information please call or e-mail and thank you for taking Gobi roof racks and accessories into consideration.
Respectfully,
Paul Badillo
GOBIUSA
Gobi Stealth Jeep Jerry Can-Cargo Tie down system images.pdf
Gobi Xterra Ranger roof rack images.pdf
Gobi Xterra Stealth roof rack images.pdf
Just a bit dusty, but I love the new rack.
DSC_5245.jpg~original
I have the Baja rack. From the ground to the top of the rail of the rack I sit at 6 ft 7 in. I love the Baja rack! When we go to the beach all the toys,chairs and boogie boards are in it. No more bring the beach back in the Runner. Now its on the roof and gets washed off. It's E Z!
Using Tapatalk
YEEEEEHAWWW!!!!! Ordered mine tonight, I will be camping out be fore you know it.
The Gobi that is.....
