Gobi rack question for lights
graciedad04
I ordered my roofrack from gobi. It is the stealth and is set up for the 4 light bars. I was just wondering if anyone has theirs set up that way also. And if you could tell me if they have the holes already there for mounting the lights or if you drill them yourself?
If you drill them yourself i was hoping for a measurement of the light bar mounting areas. If they are predrilled, i was hoping for a measurement of the mounting holes. I would like to get my lights ordered so they are here when my rack shows up.
Sent from my SM-G955U using Tapatalk
With as slow as Gobi moves, you can probably ask for lights as a Christmas gift and get them before the rack shows up
Still gotta get the measurements lol
Ask Gobi :eyebrows:
If it is like the 40" set up the brackets are pre drilled and slotted so you can move them inboard and outboard a bit to suit the size/type of light bars mounting. You best bet is to pick your lights, send those specs to Gobi and they can/should be willing to confirm fitment and/or modify the brackets a bit to make them fit. I don't see you having any problems unless you are going with some crazy design.
Yhea not looking for a crazy design. I found measurements that gobi supplies in specs. But having trouble finding which lights fit those measurements exactly since everyones brackets appear to mount at different measurements even for the same size lights.
Talyn
