today I installed the 1.5 on the back
its a bandaid fix in my opinion
I have a few more camping trips to go this summer and I have the sagging wagon thing going on. I could have just thrown some new moog springs on the back, but this was cheaper
why did I go cheap, cause this fall im doing all new springs and shocks on all corners ( not moog), the big brake upgrade, and energy suspension rack bushings and sway bar bushings.
the difference in ride was very good, made it obvious that the front is getting weak
instructions are too simplified, like a 3 step toilet ....turn off water, remove toilet, install new one
while the instructions that come with the daystars might be ok if you got a lift, it just says remove lower shock bolts , remove bolt from panhard, lower diffy, remove springs install new spacers , some prying may be needed
this is what I will add and made it so simple
remove wheels ( so much more access)
remove sway bar links ( unbolt at top at bushings)
this really made things easy to get to and with the sway bar links disconnected the diff drops even lower and is more "flexible" requiring little "prying" could install by hand with no prying with a pry bar...just muscle
I discovered this after prying hard and said to myself , drop the sway bar....made all the difference in the world
one other little thing, today I also picked up 6 ton jack stands at harbor freight, with coupon they were 39 a pair, at bottom they sit as high as 3 ton jack stands fully extended, extended they are about 7 inches higher than 3 tons, might not sound like much, but it is
