Greetings From SoCal
ExoYota
Hello my name is John from SoCal I'm 22 yrs old & I got myself a bday present last year.. I am a proud owner of a first generation 4runner.. I picked up this bad boy from its original owner last year & has been my project since.. although I haven't done much to it yet I learned that this is all a timing game So far my Runner has 220xxx miles original motor it was automatic converted to a 5 speed G52 it was a lil rancho lift I suppose I believe it will be a 4inch (not quite sure) has a 2inch body lift witch I'll be getting rid of soon it has 33 inch bf goodrich tires my goals is to do a SAS gears lockers the hole nine yards so far I picked up a T-case with 4.7 have the adabter saving up for some 5.29 Detroit lockers
~original[/IMG]
~original[/IMG]
~original[/IMG]
~original[/IMG]
~original[/IMG]
Man that's clean!
Any first gens around here look like swiss cheese with rust.
Very nice and welcome!
Thanks guys, sorry for the delay I been working on my rig ever sense the transmission conversion I been having some technical problems with my clutch feels like air is in the lines bleed the system several time clutch still don't grab replaced the clucth cylinder & negative my system set up runs backwards as I can POP into first with out the clutch then to take off I would need to use the clutch pedal as a gas pedal so clutch & gas together at the same time Hmmm weird any help.?
yutaiko
