Grinding noise on startup
jpeaslee
I've been a bit dead on the forums lately. Haven't had much exciting going on with the Runner over the last year. It usually only gets driven once or twice a week.
Over the winter, i started getting this intermittent grinding noise on startup. It'll start like normal, but immediately after it turns over and starts, there will be a grinding noise that might last a half a second. I'm guessing it's the starter. About 2 years ago I did rebuild it due to the plunger sticking, but didn't have any problem with it until maybe 4 months ago. It doesn't seem to happen as much when I've been driving it more, but that isn't exactly a scientific observation. Any thoughts on what it might be?
Yeah, it could be the starter gear not fully retracting in time and contacting the flexplate after the engine starts.
I just recently had something similar happen to me, but intermittently. When I would start the car, it would start fine, but a loud screeching/metal scraping sound would occur for like 1/2 a second. It turned out to be the flywheel scraping against a loose bolt on the steering pulley. The shop found it and tightened the bolt and never heard it again.
I had this years ago. I bought a new starter to replace mine but when I pulled it out I found it was only the washer on the starter. It got loose and would push out with the starter gear and grind for half a second before being pulled back in with the gear.
I just replaced the starter since I had it out already and it was pretty old. I would have just fixed the washer if I could go back and kept the OEM. The auto zone one has been fine for the last 6 years though.
It could be your starter motor. My 99' was making the same noise and upon pulling the starter, I discovered the gear was pretty well eaten away. A new one was about $100 from autozone and an hour and a half to two hours worth of work to diy. Starts up great and with no grinding noise everytime now.
Just to confirm, is this kinda what the noise sounds like? A low pitch grinding noise, accompanied by some sporadic higher pitch noises (which didn't come through on the video?) It sounds a whole lot worse in this video than in real-life -- way more prominent. I hear it only at startup and for the first few minutes of my drive. I've been having this happen kinda randomly for the past week or two
https://www.youtube.com/watch?v=f0QY5eVV0R4
If it’s making that noise after the engine is running for a few min I don’t think it’s the starter.
Look at the Alt. It’s bearings may be going bad.
Grinding noise on 2003 Toyota 4Runner LE on startup - YouTube
It's hard to tell from the video. You might try looking in the 4th gen section since your 2003 is a 4th gen. They might be able to recognize it easier.
Oop, didn't even notice -- thanks for the tip. I'll try posting there. I definitely think the loose flywheel bolt is the most likely issue, though the alternator is a good point I hadn't thought of.
what ?
sounds more like the nut behind the steering wheel or blinker fluid
what ?
I was trying to figure out the flywheel part myself. What I think the member ment was the bolt behind the power steering pully as you have to loosen it to adjust the power steering belt. :)
Sent from my SM-A505U using Tapatalk
CoaterZ_FL
