I've installed a set of low power fog lights under the REAR bumper of my 2003 4Runner for added light when backing up and primarily to use when I need extra light when launching/retreiving my boat at night. I'm powering direct to the positive side of the battery and using the on/off switch that came with the kit. I've double checked all the connections, etc. but as soon as I attach the power lead the in-line 15A fuse blows. The switch is grounded to the ground strap nut that runs from the negative battery post to the fender. The lights are grounded to a bolt on the factory hitch. I also tried to tap into the backup lights but then the fuse blew that controls the a/c switches and the multi-display (mileage, etc but the clock still worked.)
Question: Any idea on the best way to ground the lights and switch? I think that is my problem but open to any other suggestons/insights.
I've done this setup on other vehicles with no problems so I'm perplexed.
Thanks!
Thanks!
