MStudt
official vendor
****This group buy is officially closed!****
As many of you know, I'm the guy that makes those good sway bar links. I'm been approached by a member who asked about putting together a Group Buy opportunity. I've decided to go ahead and start the Group Buy today, and it will close on Friday May 30th. It's very hard to say how much savings will be generated from this sale. Below is a figure that I came up with, and shipping will be in addition to the charges below. I will require a $50 deposit up front, and the balance will be due within 5 days of closing.
Group Buy Prices
0-4 Sets- No savings, same pricing as below
5-9 Sets- $10 off 1 set (f or r), $15 off 2 sets (f & r)
10-19 Sets- $15 off 1 set (f or r), $20 off 2 sets (f & r)
20-49 Sets- $20 off 1 set (f or r), $25 off 2 sets (f & r)
50+ Sets- $30 off 1 set (f or r), $40 off 2 sets (f & r)
I know I'll be asked about the "sets" so I'll clear that up. One set would be considered a front or rear pair (set). Two sets would be considered 2 rears, 2 fronts, or 1 rear and 1 front.
If you are interested please send me a PM with your email address, and all payments are to be paid via Paypal. I'll add a list to the thread with the members names that are in on the group buy.
These links will work on lifts up to 3". These are made with 1/2-20 LH chromoly rod ends with nylon races. They have 3/4" hex bar that has been drill to 1/2-20 LH on one end and 1/2-20 RH on the other. The bushing side has 1/2-20 B7 threaded rod that is rated at 125,000 PSI. All links will the option of red or black Energy Suspension bushings. These will fit stock sway bar link mounts, and no drilling is required for these. You can get these made three different ways.
I'd like to give some information on the double disconnects and getting them disconnect. First off, please do not over tighten the top bushings. Over tightening the top bushings will cause you to not be able to release the top pin. If you wrench down on the bushings, you will not be able to slide the heim off the stud.
These are my double-disconnects.
Options:
If you're interested please let me know the following:
*Your email
*Zip code for shipping quote
*3rd Gen, 4th Gen, or 5th Gen (4th & 5th Gen's fronts are stock replacements only)
*Red or Black bushings
*Front/Rear/or both
Disclaimer- Please read this carefully!
*Please allow 6-10 business days for delivery*
*Please note these are an aftermarket product, that are intended for off-road use*
*They are to be installed at the owners discretion, and the owner will assume all risk*
*The builder is not responsible for any damage to any vehicles during the installation or use of these products* *It's the buyers responsibility for securing any loose parts when the links are removed*
*4th & 5th Gen- owners are responsible for securing front sway bar when disconnected*
*All sales are final*
*By purchasing these links, you understand and assume all risk*
Thanks,
Mike
Group Buy Prices
Options:
- Non-Disconnect- 2 @ $140 + shipping; 4 @ $180 x shipping
- Single-Disconnect- 2 @ $145 + shipping; 4 @ $185 + shipping
- Double-Disconnect- 2 @ $150 + shipping; 4 @ $190 + shipping
*Your email
*Front/Rear/or both
Thanks,
Mike
