Grrrr
Sworkscrux
Hopefully this is an easy one. My rear cargo 12 volt isn’t working. My front is fine . Fuses appear fine . I think I checked the right ones . Kind of stumped. Any help would be appreciated.
When checking the fuses did you just visually check them or use a multi-meter to check for continuity or swap the fuse with a known good fuse to see if that solved the issue?
Sometimes a fuse that visually looks fine can still be bad.
Also the power outlet socket itself could be bad and need replacing, did you use a multi-meter to check for voltage at the wires of the socket?
Mike Sargent
