Gullwing door panels
LOL. Just buy butyl tape and follow along the inside edges of the foam tape. Not sure how to fix the leaky lock though. The lock leak isnt bad though. The water saturates the locking mechanism, so you will see water run down the inside, window stopper/arm lever and it drips. Maybe 2 or 3 drops through a automatic car wash.
My window frame leaked cuz whoever put the foam tape on started and stopped on top, left of window and had a gap in the foam at that top left corner, and thats where the water comes in due to driving and gravity. They should have started on bottom right of window, and use one continuous foam piece with no breaks in it...but they didnt do that.
I put butyl tape behind it and that fixed it for the most part. However, I'm a paranoid person, so i added silicone to the other side of the foam tape. No leaks now around the frame.
this sounds more reassuring. i already have rago molle with the shelf, lets see how well it works together.
Yeah, butyl tape is easy to find at home depot in the roofing department. I think its 6 dollars for way more than you will ever need.
i have the rago with the gullwing, it works okay. I have 3 medium pouch that contains:
1. ARB tire repair kit (in a molle pouch)
2. ARB tire inflator kit
3. Winch controller.
i mainly stuck it there, mainly for theft prevention. When people look into the car they don't see nada because the black molle pouches hide well in between the gullwing and the rago panels. It did also free up way more space on the rago panels in the cargo bay.
didnt sound deaden the gullwings?
I hadn't considered sound deadening them based on clearance to the inside molle panel, but it's not a bad idea. I've yet to finish a bunch of projects, so I haven't driven since installing them, so I'm not sure how much road noise I'll hear through them.
seltzernator
