Hand-Held Vacuum on Power Outlet?
CopperX
Is there goona be damage to the truck if I plug the hand-held vacuum to the power outlet inside the center console? The manual says as long as it's under 115v.
The issue won't be voltage, it will be the amperage. If you overload it, you'll blow the fuse, so no damage done.
Personally, I find the handheld vacuums to be so weak that I got rid of them all and use the big one from the house or the Shop-Vac to clean the truck. Picks up everything and the noise isn't to bad for a few minutes.
