Hanma LED Bar Group Buy
Status
Not open for further replies.
My apologies if this has been addressed before. I am interested in the bc 21". Does it come with a wiring harness? If not, what are folks using? My plan is to mount it behind the grill on my 07 sport.
No, it only comes with 18-24" of wire. Any aux wiring kit from a parts store will work, or you can just buy wire, fuse, relay, and switch. These get wired up just like any auxiliary lights.
Expedition, do you have any photos or the 3x3 lights output by any chance?
I don't have any output photos of the 3x3 or single row. I have played around with the single rows quite a bit and for the money they are a GREAT purchase. I would throw those on the rack for camping or reverse lighting. Nice and sleek. I'll help answer all questions but please note this is Matt's Group Buy so I'm just helping. Maybe in the future I can run a group buy for you guys on the large scale with very similar pricing. But first I'll need to set up a vendor star, and develop a name on T4R.
Not trying to hi-jack :)
here is my dual row 30" on my 4runner that I sold....
Add a couple more for me
Let's add two more 3x3 for me, this time in flood.
That makes my total order =
t4rJohn - 2x 3x3 Spot, 2x 2x6 Spot, 1x 2x6 Flood, 2x 3x3 Flood
I'm good with either 1/15 or the later order, but of course, I'd prefer as soon as I can get them.
John .
I'm going to be in for either the 21.5 or 31.5 BC series bar.
Does anyone know the inside main hoop spacing for a Shrockworks front bumper? The 31.5" bar looks like it would be a tight squeeze. Guess I'll hit up Shrockworks for a dimension and then I'll get my order in.
Gaterose - thanks for organizing this!
One last question, the 'combo' option on the BC...is that 50/50 spot/flood?
No problem! Just let me know when you make up your mind.
I believe the 4 outside bulbs on each side have flood reflectors, but it may be 8. The middle are spot.
I don't know for sure about the SW, but the DO is just barely too small for the 30" light to fit between the hoop. I'm sure the SW is pretty close to the DO in hoop size. I think you could put it behind the hoop and only block a small part of the housing, but I think something custom would have to be done to mount the 30.
Maybe [MENTION=68704]superman3043[/MENTION] will chime in and correct me on this (both points actually)
Hey, I've been shout tagged!!! Sure, I'll chime in. Just refer to posts #217 and #228 for my thoughts regarding the questions. Link in sig. Also, some output pictures and close-ups for members in this thread interested in buying one of these. I noticed one has a good indication of the combo reflectors. Would I recommend them? Hell yes!! And working with Matt to get them makes it even better. He's my 4R hero :)
The more I stare at mine the more I think the 30" bar would have worked... But may have required a little gymnastics to get it done. Either way, I couldn't be happier.
Hope it helps!
Any decent wiring diagrams out there for these things? Wiring and I go together about like a liberal and a conservative...
Sorry I meant to respond to this yesterday, I think the forum has quit sending me email notifications on it for some reason.
I would just use the writeup on tacomaworld.com in the Mods/Tutorials drop down menu. These aren't wired any differently than any other auxiliary lights.
I think I put it in here somewhere already but these lights don't include any switches, relays, fuses, or wiring. For fuses you'll need
7.5" - 36W - 3A
12.5" - 72W - 6A
21.5" - 120W - 10A
31.5" - 180W - 15A
41.5" - 240W - 20A
2x6/3x3 - 18W - 1.5A
that's per light
Thank you, both of you.
Just let me know when you want me to send that money. Should work out good. We can file taxes on the 30th of January and should see my refund/return back w/in a week or so, then can order the DO bumper and sliders and begin figuring out how I want to mount everything.
Probably go with a dual battery set up with a Blue Sea fuse block setup at the time so I can start wiring everything to that.
Status
